OBS capturing himself when I select window capture and choose any window
grrbes
Hello, my OBS is capturing himself every time when I select some window to capture, but when I select screen capture he works normally.
I'm using Windows 7 and before I use Windows 10 when I usually used OBS too and capture window without any bugs like that.
If anyone can help me, I'd be so much grateful
  • 2022-06-06 18-38-21.txt
grrbes
Thank you, now my problem is finally solved :D
I'm sorry, just joking
But do you know some more information about it?
Harold
It's because you have aero not enabled in windows.
This is not an issue in newer versions of windows because of improvements to the aero engine that are in windows 8 and up
