OBS being open causes PC sounds to uncontrollably stutter
Kirio5
Today I have come across an issue I have never had before using OBS.
When I open the software, it causes every bit of audio from my PC to repeatedly cut in and out to the point it's painful to listen to
Example: https://drive.google.com/file/d/17j-he3-BSooo5_JYmZbTZVZmDS6mvqfr/view?usp=sharing
It occurs whenever my main scene collection is open. When I open another one, the issue stops. I have duplicated the scene collection (where the issue persists) and systematically deleted different sources and scenes to determine what is causing the issue, but again- no luck
I have tried updating OBS, restarting my PC, unplugging my interface (GoXLR mini), but to no avail
Does anyone have any suggestions?
Edit: Logfile https://obsproject.com/logs/eaOsEQPXyRFipOCC
xoPeridotTea
This has actually been happening to me for years, but the moment I switch to headphones, the audio is fine. I honestly just gave up on there ever being a solution
qhobbes
1. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows is currently known to cause performance and capture issues with OBS, games and overlay tools. If you are having issues with performance or OBS freezing, we recommend disabling it via these instructions as a troubleshooting step. Restart after disabling it.
2. Run OBS as Admin.
3. Display and Game Capture Sources interfere with each other. NEVER put them in the same scene (Small Cam).
4. Contact StreamElements to resolve their errors in your log.
If still having issues, post a new log.
xoPeridotTea
IDK about OP, but I can tell you that none of that actually fixes the issue. Followed all those steps years ago and nothing changed.
