Question / Help OBS Audio Output to Youtube LOW
Apn15
I am currently having an issue with the audio level for my youtube stream. My setup is an AverMedia Live Gamer Portable 2 plugged into a PC. I have a camera running to the capture card, and the audio is fed separately into the card from a mixer.
I have tried adjusting the audio levels with a gain filter or increasing the output from the mixing channel, even to max in OBS, but I cannot seam to get the audio level on youtube to increase.
Is there some setting for stream output that I have overlooked?
  • 2019-12-22 10-20-14.txt
Narcogen
So where is your audio coming from?
I understand you've got a capture card, and a camera. What's the audio source, and what is it connected to, and how? Sounds like you might be mixing up microphone level with line level inputs, and need a preamp but don't have one.
