OBS audio: cracking on one side.
cnm
Hi there,
I am using OBS 29.1.3 (64 bit) on a Mac mini M1, Monterey with 8 GB's of RAM. I use a couple of camera's through NDI. When I listen to the camera's on NDI video monitor, the sound seems fine. When I listen back a recording or live monitor, the right side of the audio cracks. The left side is fine. This also happens while live streaming.
Before updating, OBS and audio worked fine. When I have a non-NDI input source like a mixer through USB, the audio problem persists. This makes me think the problem is not with NDI but OBS. Does anybody have an idea how to fix this issue? I have searched everywhere, but not getting an answer.
I attached an audio sample of the issue, perhaps someone recognises is.
I'd appreciate any help.
Thanks,
Chris
  • audio-distorted.mp3.zip
cnm
If anyone has this issue, I think I installed the wrong version of NDI - OBS plugin. When you follow these steps, it will resolve the issue:
No need to remove, just follow the steps.
Good luck to anyone having similar issues.
