Dariofubar
Hey, i just recently noticed that when i use OBS with the Avermedia Live Gamer HD and i use a INGAME resolution lower than the desktop resolution, that the picture in OBS freezes and only shows the last shown frame from my desktop before i got into the game (Desktop Resolution 1080p , ingame resolution 720p). I need to change the desktop resolution to 720p as well in order to make the game show up in OBS. However if i use RECcentral to capture/stream it works fine.
I only use the Live Gamer HD as a Capture source and have it added to global sources.
I use the Live Gamer HD in a single pc setup and cloned it in my drivers with my main monitor . Everything works flawless , except for that one thing!
Logfile is attached if needed, i tested it with both output options, 1280x720p without downscaling and 1920x1080p with downscaling. Both times the same outcome , as soon as i load into the game the Desktop Picture freezes and it doesn't show the game.
On a sidenote , does this setting has any impact at all? Mabye it is just my imagination but whenever i use 1080p in this option i can stream at 60fps(set in OBS) but it doesn't look as smooth as if i use the 720p setting (in the pictures you can see that there is no way of selecting 60fps if i select 1080p).
03:49:16: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
03:49:16: -------------------------------
03:49:16: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
03:49:16: CPU Speed: 3503MHz
03:49:16: Physical Memory: 16346MB Total, 13487MB Free
03:49:16: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
03:49:16: monitor 1: pos={0, 0}, size={1920, 1080}
03:49:16: monitor 2: pos={1920, 0}, size={1920, 1080}
03:49:16: Windows Version: 6.1 Build 7601 S
03:49:16: Aero is Disabled
03:49:16: OBS Modules:
03:49:16: Base Address Module
03:49:16: 000000003FA80000 OBS.exe
03:49:16: 00000000EC280000 OBSApi.dll
03:49:16: 00000000FB190000 DShowPlugin.dll
03:49:16: 00000000FA0B0000 GraphicsCapture.dll
03:49:16: 00000000FA090000 NoiseGate.dll
03:49:16: ------------------------------------------
03:49:16: Adapter 1
03:49:16: Video Adapter: NVIDIA GeForce GTX 670
03:49:16: Video Adapter Dedicated Video Memory: 2091581440
03:49:16: Video Adapter Shared System Memory: 2147479552
03:49:16: =====Stream Start: 2013-05-24, 03:49:16===============================================
03:49:16: Multithreaded optimizations: On
03:49:16: Base resolution: 1920x1080
03:49:16: Output resolution: 1280x720
03:49:16: Loading up D3D10...
03:49:16: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:49:16: Using desktop audio input: Speakers (Creative SB X-Fi)
03:49:16: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:49:16: Audio Encoding: AAC
03:49:16: bitrate: 128
03:49:16: device: AVerMedia HD Capture C985 Bus 4,
03:49:16: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:49:16: chosen type: YV12, usingFourCC: true, res: 1920x1080 - 1920x1080, frameIntervals: 333333-666666, fourCC: 'YV12'
03:49:16: audio device: Disable,
03:49:16: audio device id Disabled,
03:49:16:
03:49:16: Using directshow input
03:49:16: Video Encoding: x264
03:49:16: fps: 60
03:49:16: width: 1280, height: 720
03:49:16: preset: veryfast
03:49:16: CBR: no
03:49:16: CFR: no
03:49:16: max bitrate: 3500
03:49:16: buffer size: 3500
03:49:16: quality: 8
03:49:17: Total frames rendered: 44, number of frames that lagged: 1 (2.27%) (it's okay for some frames to lag)
03:49:17: =====Stream End: 2013-05-24, 03:49:17=================================================
03:49:19: =====Stream Start: 2013-05-24, 03:49:19===============================================
03:49:19: Multithreaded optimizations: On
03:49:19: Base resolution: 1920x1080
03:49:19: Output resolution: 1280x720
03:49:19: ------------------------------------------
03:49:19: Loading up D3D10...
03:49:19: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:49:19: Using desktop audio input: Speakers (Creative SB X-Fi)
03:49:19: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:49:19: Audio Encoding: AAC
03:49:19: bitrate: 128
03:49:19: device: AVerMedia HD Capture C985 Bus 4,
03:49:19: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:49:19: chosen type: YV12, usingFourCC: true, res: 1920x1080 - 1920x1080, frameIntervals: 333333-666666, fourCC: 'YV12'
03:49:19: audio device: Disable,
03:49:19: audio device id Disabled,
03:49:19:
03:49:19: Using directshow input
03:49:19: Video Encoding: x264
03:49:19: fps: 60
03:49:19: width: 1280, height: 720
03:49:19: preset: veryfast
03:49:19: CBR: no
03:49:19: CFR: no
03:49:19: max bitrate: 3500
03:49:19: buffer size: 3500
03:49:19: quality: 8
03:49:23: Total frames rendered: 241, number of frames that lagged: 1 (0.41%) (it's okay for some frames to lag)
03:49:23: =====Stream End: 2013-05-24, 03:49:23=================================================
03:49:25: =====Stream Start: 2013-05-24, 03:49:25===============================================
03:49:25: Multithreaded optimizations: On
03:49:25: Base resolution: 1920x1080
03:49:25: Output resolution: 1280x720
03:49:25: ------------------------------------------
03:49:25: Loading up D3D10...
03:49:25: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:49:25: Using desktop audio input: Speakers (Creative SB X-Fi)
03:49:25: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:49:25: Audio Encoding: AAC
03:49:25: bitrate: 128
03:49:25: device: AVerMedia HD Capture C985 Bus 4,
03:49:25: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:49:25: chosen type: YV12, usingFourCC: true, res: 1920x1080 - 1920x1080, frameIntervals: 333333-666666, fourCC: 'YV12'
03:49:25: audio device: Disable,
03:49:25: audio device id Disabled,
03:49:25:
03:49:25: Using directshow input
03:49:25: Video Encoding: x264
03:49:25: fps: 60
03:49:25: width: 1280, height: 720
03:49:25: preset: veryfast
03:49:25: CBR: no
03:49:25: CFR: no
03:49:25: max bitrate: 3500
03:49:25: buffer size: 3500
03:49:25: quality: 8
03:49:28: Total frames rendered: 152, number of frames that lagged: 1 (0.66%) (it's okay for some frames to lag)
03:49:28: =====Stream End: 2013-05-24, 03:49:28=================================================
03:49:40: =====Stream Start: 2013-05-24, 03:49:40===============================================
03:49:40: Multithreaded optimizations: On
03:49:40: Base resolution: 1920x1080
03:49:40: Output resolution: 1280x720
03:49:40: ------------------------------------------
03:49:40: Loading up D3D10...
03:49:40: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:49:40: Using desktop audio input: Speakers (Creative SB X-Fi)
03:49:40: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:49:40: Audio Encoding: AAC
03:49:40: bitrate: 128
03:49:40: device: AVerMedia HD Capture C985 Bus 4,
03:49:40: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:49:40: chosen type: YV12, usingFourCC: true, res: 1920x1080 - 1920x1080, frameIntervals: 333333-666666, fourCC: 'YV12'
03:49:40: audio device: Disable,
03:49:40: audio device id Disabled,
03:49:40:
03:49:40: Using directshow input
03:49:40: Video Encoding: x264
03:49:40: fps: 60
03:49:40: width: 1280, height: 720
03:49:40: preset: veryfast
03:49:40: CBR: no
03:49:40: CFR: no
03:49:40: max bitrate: 3500
03:49:40: buffer size: 3500
03:49:40: quality: 8
03:49:42: Total frames rendered: 107, number of frames that lagged: 1 (0.93%) (it's okay for some frames to lag)
03:49:42: =====Stream End: 2013-05-24, 03:49:42=================================================
03:51:57: =====Stream Start: 2013-05-24, 03:51:57===============================================
03:51:57: Multithreaded optimizations: On
03:51:57: Base resolution: 1920x1080
03:51:57: Output resolution: 1280x720
03:51:57: ------------------------------------------
03:51:58: Loading up D3D10...
03:51:58: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:51:58: ------------------------------------------
03:51:58: Using desktop audio input: Speakers (Creative SB X-Fi)
03:51:58: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:51:58: Audio Encoding: AAC
03:51:58: bitrate: 128
03:51:58: device: AVerMedia HD Capture C985 Bus 4,
03:51:58: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:51:58: chosen type: YV12, usingFourCC: true, res: 1920x1080 - 1920x1080, frameIntervals: 333333-666666, fourCC: 'YV12'
03:51:58: audio device: Disable,
03:51:58: audio device id Disabled,
03:51:58:
03:51:58: Using directshow input
03:51:58: Video Encoding: x264
03:51:58: fps: 60
03:51:58: width: 1280, height: 720
03:51:58: preset: veryfast
03:51:58: CBR: no
03:51:58: CFR: no
03:51:58: max bitrate: 3500
03:51:58: buffer size: 3500
03:51:58: quality: 8
03:51:59: Using RTMP service: Twitch / Justin.tv
03:51:59: Server selection: rtmp://live-lhr-backup.justin.tv/app
03:52:04: SO_SNDBUF was at 8192
03:52:04: SO_SNDBUF is now 65536
03:53:40: Total frames rendered: 6055, number of frames that lagged: 4 (0.07%) (it's okay for some frames to lag)
03:53:40: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:53:40: Number of times waited to send: 0, Waited for a total of 0 bytes
03:53:40: Number of b-frames dropped: 3 (0.053%), Number of p-frames dropped: 0 (0%), Total 3 (0.053%)
03:53:40: =====Stream End: 2013-05-24, 03:53:40=================================================
03:54:16: =====Stream Start: 2013-05-24, 03:54:16===============================================
03:54:16: Multithreaded optimizations: On
03:54:16: Base resolution: 1280x720
03:54:16: Output resolution: 1280x720
03:54:16: ------------------------------------------
03:54:16: Loading up D3D10...
03:54:16: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:54:16: Using desktop audio input: Speakers (Creative SB X-Fi)
03:54:16: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:54:16: Audio Encoding: AAC
03:54:16: bitrate: 128
03:54:16: device: AVerMedia HD Capture C985 Bus 4,
03:54:16: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:54:16: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
03:54:16: audio device: Disable,
03:54:16: audio device id Disabled,
03:54:16:
03:54:16: Using directshow input
03:54:16: Video Encoding: x264
03:54:16: fps: 60
03:54:16: width: 1280, height: 720
03:54:16: preset: veryfast
03:54:16: CBR: no
03:54:16: CFR: no
03:54:16: max bitrate: 3500
03:54:16: buffer size: 3500
03:54:16: quality: 8
03:54:17: Total frames rendered: 59, number of frames that lagged: 1 (1.69%) (it's okay for some frames to lag)
03:54:17: =====Stream End: 2013-05-24, 03:54:17=================================================
03:54:20: =====Stream Start: 2013-05-24, 03:54:20===============================================
03:54:20: Multithreaded optimizations: On
03:54:20: Base resolution: 1280x720
03:54:20: Output resolution: 1280x720
03:54:20: ------------------------------------------
03:54:20: Loading up D3D10...
03:54:20: Playback device {0.0.0.00000000}.{76a0ea18-8d1a-4686-900c-6b980b7bd7cf}
03:54:20: Using desktop audio input: Speakers (Creative SB X-Fi)
03:54:20: Using auxilary audio input: Microphone (Creative SB X-Fi)
03:54:20: Audio Encoding: AAC
03:54:20: bitrate: 128
03:54:20: device: AVerMedia HD Capture C985 Bus 4,
03:54:20: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&256f5a3a&0&00e3#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
03:54:20: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
03:54:20: audio device: Disable,
03:54:20: audio device id Disabled,
03:54:20:
03:54:20: Using directshow input
03:54:20: Video Encoding: x264
03:54:20: fps: 60
03:54:20: width: 1280, height: 720
03:54:20: preset: veryfast
03:54:20: CBR: no
03:54:20: CFR: no
03:54:20: max bitrate: 3500
03:54:20: buffer size: 3500
03:54:20: quality: 8
03:54:22: Using RTMP service: Twitch / Justin.tv
03:54:22: Server selection: rtmp://live-lhr-backup.justin.tv/app
03:54:24: SO_SNDBUF was at 8192
03:54:24: SO_SNDBUF is now 65536
03:54:36: Total frames rendered: 854, number of frames that lagged: 6 (0.70%) (it's okay for some frames to lag)
03:54:37: RTMPPublisher::SocketLoop: Aborting due to bStopping
03:54:37: Number of times waited to send: 0, Waited for a total of 0 bytes
03:54:37: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
03:54:37: =====Stream End: 2013-05-24, 03:54:37=================================================
03:57:19:
03:57:19: Profiler results:
03:57:19:
03:57:19: ==============================================================
03:57:19: frame - [100%] [avg time: 2.432 ms] [avg calls per frame: 1] [children: 67.8%] [unaccounted: 32.2%]
03:57:19: | scene->Preprocess - [16.3%] [avg time: 0.396 ms] [avg calls per frame: 1]
03:57:19: | video encoding and uploading - [51.6%] [avg time: 1.254 ms] [avg calls per frame: 1] [children: 46.9%] [unaccounted: 4.65%]
03:57:19: | | CopyResource - [0.781%] [avg time: 0.019 ms] [avg calls per frame: 0]
03:57:19: | | conversion to 4:2:0 - [0.123%] [avg time: 0.003 ms] [avg calls per frame: 0]
03:57:19: | | call to encoder - [45.8%] [avg time: 1.114 ms] [avg calls per frame: 0]
03:57:19: | | sending stuff out - [0.206%] [avg time: 0.005 ms] [avg calls per frame: 0]
03:57:19:
03:49:16: Adapter 1
03:49:16:
03:49:16: fps: 60
03:49:16: CBR: no
03:49:16: CFR: no
03:49:19:
03:49:19: fps: 60
03:49:19: CBR: no
03:49:19: CFR: no
03:49:25:
03:49:25: fps: 60
03:49:25: CBR: no
03:49:25: CFR: no
03:49:40:
03:49:40: fps: 60
03:49:40: CBR: no
03:49:40: CFR: no
03:51:58:
03:51:58: fps: 60
03:51:58: CBR: no
03:51:58: CFR: no
03:54:16:
03:54:16: fps: 60
03:54:16: CBR: no
03:54:16: CFR: no
03:54:20:
03:54:20: fps: 60
03:54:20: CBR: no
03:54:20: CFR: no
03:57:19:
03:57:19:
03:57:19:
