Disable any antivirus software you're using during the installation process and whitelist the OBS directory afterwards. If this is a clean install (the file doesn't already exist/OBS isn't running) then that's the most common culprit.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
