Luis Alvarado
Hi OBS Team, first let me congratulate you on this amazing software. It is basically the only reason I have https://youtube.com/@xtremelinux so thank you so much.
Now, the issue I happened to simply stumble by luck today that has actually solved the doubt I had about a performance issue with Nvidia since about 6 months ago is the following. Using OBS 30.0.2 (Could even go down to 29) is that, even without recording, the FPS value of several games while having OBS opened (again, without recording, streaming or anything, just opened in the background) makes the game drop 40+ FPS. I did not fully notice this since I have an Nvidia 4090 but today I was testing GTA5 and while closing OBS before the game I notice the boost immediately on the game. I will leave some screenshots here for ideas. I managed to pin point the issue to the following section:
I record at 4K with 60 FPS but the issue also happens at 2K or 1080p. If you set it to 30 fps or 60 fps it will happen. It drops X amount of FPS off the game in relation to the Common FPS Value that is set. In the following images you will see the impact with and without having OBS opened (Again, I am not recording or anything):
RDR2 (4K - Ultra High Settings) - OBS CLOSED
RDR2 (4K - Ultra High Settings) - OBS OPENED (Not recording, just opened)
GTA5 (4K - Ultra High Settings) - OBS CLOSED
GTA5 (4K - Ultra High Settings) - OBS OPENED (Not recording, just opened)
HOGWARTS LEGACY (4K - Ultra High Settings) - OBS CLOSED
HOGWARTS LEGACY (4K - Ultra High Settings) - OBS OPENED (Not recording, just opened)
CYBERPUNK (4K - Ultra High Settings) - OBS CLOSED
CYBERPUNK (4K - Ultra High Settings) - OBS OPENED (Not recording, just opened)
I have tested leaving the encoder in x264 and NVENC, both produce the same FPS results as shown above. Same for changing resolution. But, if I change the Common FPS value it changes the FPS value on the game immediately. Just wanted you guys to know about this "issue" as in, without even recording the FPS value goes down super fast. And the computer is not old, here are the specs in case in helps:
