OBS 30.0.1 Ubuntu 22.04 crashes after initial load
OldOwl
I'm not sure when this started as I only use OBS every so often but I've tried to uninstall/reinstall OBS. I've removed the ~/.config/obs-studio been using and let it generate a new one. Same issue occurs.
Issue:
- Open OBS and it'll load but then instantly close be in in normal or safe mode
- Delete ~/.config/obs-studio
- Open OBS and it'll open like new with Auto Config. If you do Auto Config or just cancel out of Auto Config the program will work as it is suppose to. When you close the program it closes like normal
- When you reopen OBS it is now broken again and it instantly close after flashing a window
Attached is the console output for first and second runs as described above
  • firstRun.log
  • secondRun.log
