OBS 26.0.2 Crash on NDI input + virtual webcam + VB cable
sandervg
We are using obs to switch two NDI sources (using websockets and compagnion) and output these to the build in virtual webcam. This runs for a variable time and then obs crashes without any interaction from the user. Please see attached my crash report and logs.
Crash log reported: https://obsproject.com/logs/lKzBOqIf8VEvpD1A
  • crashReport.txt
  • logs.txt
sandervg
The crash seems to be coming from the websocket plugin.
We are using the websocket quite a lot but this is the first time we connect localhost. So companion is connected to obs on the same machine using 127.0.0.1 will try to connect from a different machine or to disable the websocket plugin and see if it stops crashing.
Thanks for the reply
