Question / Help OBS 24.0.3 crashing switching scenes
Zonflux
Is anyone able to help me out here?
OBS is randomly but frequently crashing for me regardless of whether I am live or not when I am switching scenes.
Below I have inserted a link to the most recent crash log.
Crash Log 2020-01-01, 12:07:17
Through offline testing it appears to only happen switching to specific scenes, or at least more frequently on those scenes perhaps.
On a scene where OBS crashes frequently I have determined that the display capture is the culprit. If I edit the json for the scene and remove the display capture then I can switch to the scene without incident but as soon as I add a display capture back to the scene (which works) if I later change scenes and then go back to the scene with the display capture then it will crash again.
edit #1: If I edit the json scene file and set the display capture visibility to false then that also fixes it.
