Question / Help Not compatible with EAC (anymore)
micronn
After update of game CS:GO and EAC I can't stream my gameplay when EAC is enabled.
Yesterday everything was ok.
EAC = Easy Anti-Cheat (need to have it to play on EAC servers - http://www.leetway.com)
Thanks in advance for help.
  • 2013-05-23-2122-34.log
  • captureHookLog.txt
  • 2013-05-23-2129-44.log
Lain
Lain
run OBS as admin, or if EAC is complaining, run CS:GO in a windowed mode (such as borderless preferably) and use window capture on the game window
micronn
OBS as admin = still black screen
CS:GO in a windowed mode = still black screen
Used Window capture on the game window = working but I can't play like that (because I have small screen on desktop, hard to play), I need the solution for fullscreen, yesterday everything was working fine.
Xianahru
I think there is borderless Windowed mode available in CS:GO. Its basically the same as Fullscreen, only that you are actually running it in a window without visible borders.
micronn
Yes, but I'm not playing on native resolution and game screen is too small.
micronn
WayZHC said:
There should be still option for the resolution when you are running it in borderless window mode?
Yes, there is but I can't play on borderless window mode, I need 75Hz and fullscreen.
Desktop resolution: 1280x1024
Game resolution: 1024x768
I don't want to change it.
Two days ago it was all fine right now I get error:
"Warning -- GraphicsCaptureSource::BeginScene: Failed to inject library, GetLastError = 5"
I need a software solution not the poor alternative one.
WayZHC
Hey what's your Anti-Virus software? That error looks to me that the GraphicsCaptureHook.dll files are deleted. My Norton 360 deleted them always saying they were not safe. I put an exeption for "C:\Program Files (x86)\OBS" location so it doesn't do it anymore
WayZHC
Well check anyway for the files. If they are still there, they are not causing the problem. If one or more of them are missing try reinstalling OBS
Check both of there folders:
C:\Program Files (x86)\OBS\plugins\GraphicsCapture
C:\Program Files (x86)\OBS\64bit\plugins\GraphicsCapture
You should find 4 files from both of the locations:
GraphicsCaptureHook64.dll
injectHelper.exe
injectHelper64.exe
micronn
Everything fine with these files.
Btw. author of EAC wrote that he will look into making EAC to allow OBS working with the game again.
WayZHC
Okay cool. Nice to see they are fixing it :p I asked to check those just in case it's not EAC's problem. But looks like it's their problem :p
micronn
Author of EAC said:
EAC is preventing all other software injecting their code to the game. While this effectively prevents cheats from accessing the game memory (to some extent), it also prevents OBS from loading itself in the game.
I'm working on solution to allow OBS to work, while preventing the possibility of cheats impersonating as OBS to load themselves instead.
More information soon...
micronn
Damn few weeks ;_;
Maybe OBS developers can fix it faster?
Author of EAC said:
EAC was updated with this new functionality on 22nd May.
I cannot give an ETA on this yet, sorry. Hopefully few weeks.
