Bug Report No connection made because target refused it?
Status
Not open for further replies.
yumigoto
Earlier today I was streaming on my twitch account, I got off, and came back on 3 hours later and it came up with this
Ive tried un installing, re installing, Im not really good with stuff like this....
21:16:49: Open Broadcaster Software v0.583b - 32bit (´・ω・`)
21:16:49: -------------------------------
21:16:49: CPU Name: Intel(R) Core(TM) i7-3630QM CPU @ 2.40GHz
21:16:49: CPU Speed: 2394MHz
21:16:49: Physical Memory:  4095MB Total, 4095MB Free
21:16:49: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
21:16:49: monitor 1: pos={0, 0}, size={1366, 768}
21:16:49: Windows Version: 6.1 Build 7601 S
21:16:49: Aero is Enabled
21:16:49: OBS Modules:
21:16:49: Base Address     Module
21:16:49: 00BB0000         OBS.exe
21:16:49: 65DA0000         OBSApi.dll
21:16:49: 6D310000         DShowPlugin.dll
21:16:49: 6D2F0000         GraphicsCapture.dll
21:16:49: 6E8E0000         NoiseGate.dll
21:16:49: 6D230000         PSVPlugin.dll
21:16:49: ------------------------------------------
21:16:49: Adapter 1
21:16:49:   Video Adapter: Intel(R) HD Graphics 4000
21:16:49:   Video Adapter Dedicated Video Memory: 67108864
21:16:49:   Video Adapter Shared System Memory: 1711276032
21:16:49:   Video Adapter Output 1: pos={0, 0}, size={1366, 768}, attached=true
21:16:49: Adapter 2
21:16:49:   Video Adapter: NVIDIA GeForce GT 650M
21:16:49:   Video Adapter Dedicated Video Memory: 1022164992
21:16:49:   Video Adapter Shared System Memory: 3221221376
21:16:49: =====Stream Start: 2013-10-28, 21:16:49===============================================
21:16:49:   Multithreaded optimizations: On
21:16:49:   Base resolution: 1366x768
21:16:49:   Output resolution: 1364x768
21:16:49: Loading up D3D10 on Intel(R) HD Graphics 4000...
21:16:49: Audio Format: 48000hz
21:16:49: Playback device Default
21:16:49: Using desktop audio input: Speakers (Sound Blaster Recon3Di)
21:16:49: Using auxilary audio input: Microphone (USB Chat Headset)
21:16:49: Audio Encoding: AAC
21:16:49:     bitrate: 128
21:16:49: Scene buffering time set to 400
21:16:49: Video Encoding: x264
21:16:49:     fps: 30
21:16:49:     width: 1364, height: 768
21:16:49:     preset: veryfast
21:16:49:     profile: high
21:16:49:     keyint: 60
21:16:49:     CBR: yes
21:16:49:     CFR: yes
21:16:49:     max bitrate: 3300
21:16:49:     buffer size: 1080
21:16:49: MMDeviceAudioSource: Frequency for device 'Speakers (Sound Blaster Recon3Di)' is 384000, samples per sec is 48000
21:16:49: MMDeviceAudioSource: Frequency for device 'Microphone (USB Chat Headset)' is 384000, samples per sec is 48000
21:16:51: Using RTMP service: Twitch / Justin.tv
21:16:51:   Server selection: rtmp://live-lax-backup.justin.tv/app
21:16:51:   Interface: Intel(R) Centrino(R) Wireless-N 2230 (802.11, 54 mbps)
21:16:52: librtmp error: RTMP_Connect0, failed to connect socket: No connection could be made because the target machine actively refused it. (10061)
21:16:52: Connection to rtmp://live-lax-backup.justin.tv/app failed: Could not connect to server
21:16:52:
21:16:52: RTMP_Connect0, failed to connect socket: No connection could be made because the target machine actively refused it. (10061)
21:16:52:
21:16:53: Total frames encoded: 108, total frames duplicated: 0 (0.00%)
21:16:53: Total frames rendered: 112, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:16:53: Number of times waited to send: 0, Waited for a total of 0 bytes
21:16:53: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
21:16:53: Number of bytes sent: 0
21:16:54:
21:16:54: Profiler time results:
21:16:54:
21:16:54: ==============================================================
21:16:54: video thread frame - [100%] [avg time: 1.589 ms] [children: 22.2%] [unaccounted: 77.8%]
21:16:54: | scene->Preprocess - [0.126%] [avg time: 0.002 ms]
21:16:54: | GPU download and conversion - [22%] [avg time: 0.35 ms] [children: 21.8%] [unaccounted: 0.189%]
21:16:54: | | flush - [4.97%] [avg time: 0.079 ms]
21:16:54: | | CopyResource - [16.5%] [avg time: 0.262 ms]
21:16:54: | | conversion to 4:2:0 - [0.378%] [avg time: 0.006 ms]
21:16:54: Convert444Threads - [100%] [avg time: 0.915 ms] [children: 98.4%] [unaccounted: 1.64%]
21:16:54: | Convert444toNV12 - [98.4%] [avg time: 0.9 ms]
21:16:54: encoder thread frame - [100%] [avg time: 2.035 ms]
21:16:54:
21:16:54:
21:16:54: Profiler CPU results:
21:16:54:
21:16:54: video thread frame - [cpu time: avg 0.975 ms, total 109.2 ms] [avg calls per frame: 1]
21:16:54: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:16:54: | GPU download and conversion - [cpu time: avg 0.557 ms, total 62.4 ms] [avg calls per frame: 1]
21:16:54: | | flush - [cpu time: avg 0.417 ms, total 46.8 ms] [avg calls per frame: 1]
21:16:54: | | CopyResource - [cpu time: avg 0.159 ms, total 15.6 ms] [avg calls per frame: 1]
21:16:54: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:16:54: Convert444Threads - [cpu time: avg 0.964 ms, total 187.2 ms] [avg calls per frame: 2]
21:16:54: | Convert444toNV12 - [cpu time: avg 0.964 ms, total 187.2 ms] [avg calls per frame: 2]
21:16:54: encoder thread frame - [cpu time: avg 1.787 ms, total 171.601 ms] [avg calls per frame: 1]
21:16:54:
21:16:54: =====Stream End: 2013-10-28, 21:16:54=================================================
paibox
heros in an halfshel
This is not a bug, you are merely trying to stream to a server that isn't online. Pick a different one.
Status
