No audio on 31.1.2
sfl60
I update the version to 31.1.2 this morning and no audio is recording. Everything works except the capture of audio, on any source.
Please attach the corresponding log file.
[edit]
Just did a quick test and the audio is actually recorded. Microphone and a background video.
[/edit]
sfl60
12:24:54.418: CPU Name: 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
12:24:54.419: CPU Speed: 2803MHz
12:24:54.419: Physical Cores: 4, Logical Cores: 8
12:24:54.419: Physical Memory: 16183MB Total, 3343MB Free
12:24:54.419: Windows Version: 10.0 Build 26100 (release: 24H2; revision: 4652; 64-bit)
12:24:54.419: Running as administrator: false
12:24:54.419: Windows 10/11 Gaming Features:
12:24:54.419: Game DVR: On
12:24:54.419: Game Mode: Probably On (no reg key set)
12:24:54.421: Sec. Software Status:
12:24:54.422: Kaspersky Endpoint Security for Windows: enabled (AV)
12:24:54.422: Microsoft Defender Antivirus: disabled (AV)
12:24:54.423: Kaspersky Endpoint Security for Windows: disabled (FW)
12:24:54.423: Windows Firewall: disabled (FW)
12:24:54.425: Current Date/Time: 2025-07-30, 12:24:54
12:24:54.425: Browser Hardware Acceleration: true
12:24:54.425: Hide OBS windows from screen capture: false
12:24:54.425: Qt Version: 6.8.3 (runtime), 6.8.3 (compiled)
12:24:54.425: Portable mode: false
12:24:54.751: OBS 31.1.2 (64-bit, windows)
12:24:54.751: ---------------------------------
12:24:54.761: ---------------------------------
12:24:54.761: audio settings reset:
12:24:54.761: samples per sec: 48000
12:24:54.761: speakers: 2
12:24:54.761: max buffering: 960 milliseconds
12:24:54.761: buffering type: dynamically increasing
12:24:54.774: ---------------------------------
12:24:54.774: Initializing D3D11...
12:24:54.774: Available Video Adapters:
12:24:54.781: Adapter 0: Intel(R) Iris(R) Xe Graphics
12:24:54.781: Dedicated VRAM: 134217728 (0.1 GiB)
12:24:54.781: Shared VRAM: 8484712448 (7.9 GiB)
12:24:54.781: PCI ID: 8086:9a49
12:24:54.781: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
12:24:54.782: Driver Version: 32.0.101.6913
12:24:54.782: output 0:
12:24:54.782: name=HP E273m
12:24:54.782: pos={0, 0}
12:24:54.782: size={1920, 1080}
12:24:54.782: attached=true
12:24:54.782: refresh=60
12:24:54.782: bits_per_color=8
12:24:54.782: space=RGB_FULL_G22_NONE_P709
12:24:54.782: primaries=[r=(0.653320, 0.335938), g=(0.322266, 0.609375), b=(0.152344, 0.059570), wp=(0.313477, 0.329102)]
12:24:54.782: relative_gamut_area=[709=1.019538, P3=0.751574, 2020=0.539204]
12:24:54.782: sdr_white_nits=80
12:24:54.782: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
12:24:54.782: dpi=96 (100%)
12:24:54.782: id=\\?\DISPLAY#HPN346E#8&1b07b08d&0&UID257#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
12:24:54.782: alt_id=\\.\DISPLAY13
12:24:54.784: output 1:
12:24:54.784: name=HP E243m
12:24:54.784: pos={1920, 0}
12:24:54.784: size={1920, 1080}
12:24:54.784: attached=true
12:24:54.784: refresh=60
12:24:54.784: bits_per_color=8
12:24:54.784: space=RGB_FULL_G22_NONE_P709
12:24:54.784: primaries=[r=(0.638672, 0.357422), g=(0.308594, 0.637695), b=(0.152344, 0.069336), wp=(0.313477, 0.329102)]
12:24:54.784: relative_gamut_area=[709=1.032556, P3=0.761170, 2020=0.546089]
12:24:54.784: sdr_white_nits=80
12:24:54.784: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
12:24:54.784: dpi=96 (100%)
12:24:54.784: id=\\?\DISPLAY#HPN3466#8&1b07b08d&0&UID259#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
12:24:54.784: alt_id=\\.\DISPLAY14
12:24:54.785: Adapter 1: Intel(R) Iris(R) Xe Graphics
12:24:54.785: Dedicated VRAM: 134217728 (0.1 GiB)
12:24:54.785: Shared VRAM: 8484712448 (7.9 GiB)
12:24:54.785: PCI ID: 8086:9a49
12:24:54.785: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
12:24:54.785: Driver Version: 32.0.101.6913
12:24:54.786: Loading up D3D11 on adapter Intel(R) Iris(R) Xe Graphics (0)
12:24:54.829: D3D11 loaded successfully, feature level used: b000
12:24:54.830: DXGI increase maximum frame latency success
12:24:54.908: ---------------------------------
12:24:54.908: video settings reset:
12:24:54.908: base resolution: 1920x1080
12:24:54.908: output resolution: 1280x720
12:24:54.908: downscale filter: Bicubic
12:24:54.908: fps: 30/1
12:24:54.908: format: NV12
12:24:54.908: YUV mode: Rec. 709/Partial
12:24:54.909: NV12 texture support enabled
12:24:54.909: P010 texture support not available
12:24:54.912: Audio monitoring device:
12:24:54.912: name: Predefinito
12:24:54.912: id: default
12:24:54.916: ---------------------------------
12:24:54.918: No AJA devices found, skipping loading AJA UI plugin
12:24:54.918: Failed to initialize module 'aja-output-ui.dll'
12:24:54.919: No AJA devices found, skipping loading AJA plugin
12:24:54.919: Failed to initialize module 'aja.dll'
12:24:54.919: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
12:24:54.931: [CoreAudio encoder]: Adding CoreAudio AAC encoder
12:24:54.932: Failed to load 'en-US' text for module: 'decklink-captions.dll'
12:24:54.933: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
12:24:54.939: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
12:24:54.939: Failed to initialize module 'decklink.dll'
12:24:54.949: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
12:24:54.949: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
12:24:54.950: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
12:24:54.951: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
12:24:54.951: Failed to get NVVideoEffects.dll version info size
12:24:54.952: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
12:24:54.961: [obs-browser]: Version 2.25.3
12:24:54.961: [obs-browser]: CEF Version 127.0.6533.120 (runtime), 127.145.7+g2b7d20b+chromium-127.0.6533.120 (compiled)
12:24:54.961: [obs-browser]: Blacklisted device detected, disabling browser source hardware acceleration.
12:24:54.968: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
12:24:54.968: (126)
12:24:54.968: NVENC not supported
12:24:54.968: Failed to initialize module 'obs-nvenc.dll'
12:24:55.695: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.6.2 | RPC Version: 1)
12:24:55.695: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.8.3 | Qt version (run-time): 6.8.3
12:24:55.695: [obs-websocket] [obs_module_load] Linked ASIO Version: 103200
12:24:55.695: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
12:24:55.701: [obs-websocket] [obs_module_load] Module loaded.
12:24:55.709: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
12:24:55.723: ---------------------------------
12:24:55.723: Loaded Modules:
12:24:55.723: win-wasapi.dll
12:24:55.723: win-dshow.dll
12:24:55.723: win-capture.dll
12:24:55.723: vlc-video.dll
12:24:55.723: text-freetype2.dll
12:24:55.723: rtmp-services.dll
12:24:55.723: obs-x264.dll
12:24:55.723: obs-websocket.dll
12:24:55.723: obs-webrtc.dll
12:24:55.723: obs-vst.dll
12:24:55.723: obs-transitions.dll
12:24:55.723: obs-text.dll
12:24:55.723: obs-qsv11.dll
12:24:55.723: obs-outputs.dll
12:24:55.723: obs-filters.dll
12:24:55.723: obs-ffmpeg.dll
12:24:55.723: obs-browser.dll
12:24:55.723: nv-filters.dll
12:24:55.723: image-source.dll
12:24:55.723: frontend-tools.dll
12:24:55.723: decklink-output-ui.dll
12:24:55.723: decklink-captions.dll
12:24:55.723: coreaudio-encoder.dll
12:24:55.723: Available Encoders:
12:24:55.723: Video Encoders:
12:24:55.723: - ffmpeg_svt_av1 (SVT-AV1)
12:24:55.723: - ffmpeg_aom_av1 (AOM AV1)
12:24:55.723: - obs_qsv11_v2 (QuickSync H.264)
12:24:55.723: - obs_qsv11_hevc (QuickSync HEVC)
12:24:55.723: - obs_x264 (x264)
12:24:55.723: Audio Encoders:
12:24:55.723: - CoreAudio_AAC (CoreAudio AAC)
12:24:55.723: - ffmpeg_aac (FFmpeg AAC)
12:24:55.723: - ffmpeg_opus (FFmpeg Opus)
12:24:55.723: - ffmpeg_pcm_s16le (PCM FFmpeg (16 bit))
12:24:55.723: - ffmpeg_pcm_s24le (PCM FFmpeg (24 bit))
12:24:55.723: - ffmpeg_pcm_f32le (PCM FFmpeg (32 bit virgola mobile))
12:24:55.723: - ffmpeg_alac (ALAC FFmpeg (24 bit))
12:24:55.723: - ffmpeg_flac (FLAC FFmpeg (16 bit))
12:24:55.723: ==== Startup complete ===============================================
12:24:55.794: All scene data cleared
12:24:55.794: ------------------------------------------------
12:24:55.797: [win-wasapi: 'Audio del desktop'] update settings:
12:24:55.797: device id: default
12:24:55.797: use device timing: 1
12:24:55.798: [Loaded global audio device]: 'Audio del desktop'
12:24:55.798: [win-wasapi: 'Microfono/disp. ausiliario'] update settings:
12:24:55.798: device id: default
12:24:55.798: use device timing: 0
12:24:55.798: [Loaded global audio device]: 'Microfono/disp. ausiliario'
12:24:55.799: [win-wasapi: 'Microfono/disp. ausiliario 2'] update settings:
12:24:55.799: device id: default
12:24:55.799: use device timing: 0
12:24:55.799: [Loaded global audio device]: 'Microfono/disp. ausiliario 2'
12:24:55.801: [duplicator-monitor-capture: 'Ufficio_1'] update settings:
12:24:55.801: display: HP E273m (1920x1080)
12:24:55.801: cursor: true
12:24:55.801: method: WGC
12:24:55.801: id: \\?\DISPLAY#HPN346E#8&1b07b08d&0&UID257#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
12:24:55.801: alt_id: \\.\DISPLAY13
12:24:55.801: setting_id: \\?\DISPLAY#HPN346E#8&1b07b08d&0&UID257#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
12:24:55.801: force SDR: false
12:24:55.802: Switched to scene 'Scena'
12:24:55.802: ------------------------------------------------
12:24:55.802: Loaded scenes:
12:24:55.802: - scene 'Scena':
12:24:55.802: - source: 'Ufficio_1' (monitor_capture)
12:24:55.810: [WASAPISource::TryInitialize]:[Auricolare e microtelefono (Jabra EVOLVE LINK MS)] Failed to initialize audio client: 80070057
12:24:55.810: WASAPI: Device 'default' failed to start (source: Audio del desktop)
12:24:55.812: [WASAPISource::TryInitialize]:[Cuffia auricolare con microfono (Jabra EVOLVE LINK MS)] Failed to initialize audio client: 80070057
12:24:55.812: WASAPI: Device 'default' failed to start (source: Microfono/disp. ausiliario 2)
12:24:55.814: [WASAPISource::TryInitialize]:[Cuffia auricolare con microfono (Jabra EVOLVE LINK MS)] Failed to initialize audio client: 80070057
12:24:55.814: WASAPI: Device 'default' failed to start (source: Microfono/disp. ausiliario)
Alex_023
And don't support audio recording from Bluetooth audio devices like Defender FreeMotion B445 (Stereo wireless headset). No connection to desktop audio, and headset microphone too.
bernardking
I am having the same problems as well. No audio. Everything else seems to be working fine but the audio. I can't livestream now. my business is being compromised.
