21:38:29: Open Broadcaster Software v0.60b - 32bit (´・ω・`)
21:38:29: -------------------------------
21:38:29: CPU Name: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
21:38:29: CPU Speed: 2292MHz
21:38:29: Physical Memory: 4010MB Total, 2026MB Free
21:38:29: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
21:38:29: monitor 1: pos={0, 0}, size={1600, 900}
21:38:29: Windows Version: 6.1 Build 7601 S
21:38:29: Aero is Disabled
21:38:29: OBS Modules:
21:38:29: Base Address Module
21:38:29: 01250000 OBS.exe
21:38:29: 6D400000 OBSApi.dll
21:38:29: 73E10000 DShowPlugin.dll
21:38:29: 73C70000 GraphicsCapture.dll
21:38:29: 73C50000 NoiseGate.dll
21:38:29: 73C30000 PSVPlugin.dll
21:38:29: ------------------------------------------
21:38:29: Adapter 1
21:38:29: Video Adapter: Intel(R) HD Graphics Family
21:38:29: Video Adapter Dedicated Video Memory: 67108864
21:38:29: Video Adapter Shared System Memory: 1711276032
21:38:29: Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
21:38:29: =====Stream Start: 2014-02-13, 21:38:29===============================================
21:38:29: Multithreaded optimizations: On
21:38:29: Base resolution: 1600x900
21:38:29: Output resolution: 1600x900
21:38:29: Loading up D3D10 on Intel(R) HD Graphics Family (Adapter 1)...
21:38:30: ------------------------------------------
21:38:30: Audio Format: 44100hz
21:38:30: Playback device Default
21:38:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
21:38:30: Using auxilary audio input: Microphone (Blue Snowball)
21:38:30: Audio Encoding: MP3
21:38:30: bitrate: 64
21:38:30: Using Monitor Capture
21:38:30: Scene buffering time set to 700
21:38:30: Video Encoding: x264
21:38:30: fps: 60
21:38:30: width: 1600, height: 900
21:38:30: preset: veryfast
21:38:30: profile: high
21:38:30: keyint: 250
21:38:30: CBR: no
21:38:30: CFR: no
21:38:30: max bitrate: 4000
21:38:30: buffer size: 4000
21:38:30: quality: 10
