17:55:12: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
17:55:12: -------------------------------
17:55:12: CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
17:55:12: CPU Speed: 3400MHz
17:55:12: Physical Memory: 16351MB Total, 11452MB Free
17:55:12: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
17:55:12: monitor 1: pos={0, 0}, size={1920, 1080}
17:55:12: monitor 2: pos={1920, 0}, size={1680, 1050}
17:55:12: Windows Version: 6.1 Build 7601 S
17:55:12: Aero is Enabled
17:55:12: OBS Modules:
17:55:12: Base Address Module
17:55:12: 000000003F3E0000 OBS.exe
17:55:12: 00000000DA6A0000 OBSApi.dll
17:55:12: 00000000F45D0000 DShowPlugin.dll
17:55:12: 00000000E0D60000 GraphicsCapture.dll
17:55:12: 00000000F18A0000 NoiseGate.dll
17:55:12: ------------------------------------------
17:55:12: Adapter 1
17:55:12: Video Adapter: AMD Radeon HD 6800 Series
17:55:12: Video Adapter Dedicated Video Memory: 1052471296
17:55:12: Video Adapter Shared System Memory: 4009304064
17:55:12: =====Stream Start: 2013-07-01, 17:55:12===============================================
17:55:12: Multithreaded optimizations: On
17:55:12: Base resolution: 1920x1080
17:55:12: Output resolution: 1920x1080
17:55:12: Loading up D3D10...
17:55:12: Playback device Default
17:55:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
17:55:12: Using auxilary audio input: Microphone (Realtek High Definition Audio)
17:55:12: Audio Encoding: AAC
17:55:12: bitrate: 128
17:55:12: Using text output
17:55:12: Using graphics capture
17:55:12: device: Professional financial camera,
17:55:12: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
17:55:12: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
17:55:12: audio device: Disable,
17:55:12: audio device id Disabled,
17:55:12:
17:55:12: Using directshow input
17:55:12: Using Monitor Capture
17:55:12: Video Encoding: x264
17:55:12: fps: 25
17:55:12: width: 1920, height: 1080
17:55:12: preset: veryfast
17:55:12: CBR: no
17:55:12: CFR: no
17:55:12: max bitrate: 3500
17:55:12: buffer size: 3500
17:55:12: quality: 5
17:55:14: Using RTMP service: Twitch / Justin.tv
17:55:14: Server selection: rtmp://live-fra.justin.tv/app
17:55:15: SO_SNDBUF was at 8192
17:55:15: SO_SNDBUF is now 65536
17:55:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
17:55:16: New Scene
17:55:16: ------------------------------------------
17:55:16: device: Professional financial camera,
17:55:16: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
17:55:16: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
17:55:16: audio device: Disable,
17:55:16: audio device id Disabled,
17:55:16:
17:55:16: Using directshow input
17:55:16: Using text output
17:55:16: Using bitmap image
17:55:17: Using graphics capture
Warning -- DShowPlugin: control->Run failed, result = 8007001F
17:55:18: using memory capture
18:53:31: ------------------------------------------
18:53:31: device: Professional financial camera,
18:53:31: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
18:53:31: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
18:53:31: audio device: Disable,
18:53:31: audio device id Disabled,
18:53:31:
18:53:31: Using directshow input
20:48:07: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:48:07: New Scene
20:48:07: Using graphics capture
20:48:07: Using text output
20:48:07: ------------------------------------------
20:48:07: device: Dxtory Video 1,
20:48:07: device id (null),
20:48:07: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 400000-400000, fourCC: 00000000
20:48:07: audio device: Disable,
20:48:07: audio device id Disabled,
20:48:07:
20:48:07: Using directshow input
20:48:07: device: Professional financial camera,
20:48:07: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:48:07: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:48:07:
20:48:07: Using bitmap image
20:48:08: using memory capture
20:48:11: ------------------------------------------
20:48:11: device: Professional financial camera,
20:48:11: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:48:11: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:48:11: audio device: Disable,
20:48:11: audio device id Disabled,
20:48:11:
20:48:11: Using directshow input
20:54:53: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:54:53: New Scene
20:54:53: Using text output
20:54:53: Using graphics capture
20:54:53: Using Window Capture
20:54:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:54:54: New Scene
20:54:54: Using text output
20:54:54: Using graphics capture
20:54:54: ------------------------------------------
20:54:54: device: Professional financial camera,
20:54:54: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:54:54: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:54:54: audio device: Disable,
20:54:54: audio device id Disabled,
20:54:54:
20:54:54: Using directshow input
20:54:54: Using Monitor Capture
20:54:55: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:54:55: New Scene
20:54:55: ------------------------------------------
20:54:55: device: Professional financial camera,
20:54:55: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:54:55: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:54:55: audio device: Disable,
20:54:55: audio device id Disabled,
20:54:55:
20:54:55: Using directshow input
20:54:55: Using text output
20:54:55: Using bitmap image
20:54:55: Using graphics capture
20:54:56: using memory capture
20:54:58: ------------------------------------------
20:54:58: device: Professional financial camera,
20:54:58: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:54:58: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:54:58: audio device: Disable,
20:54:58: audio device id Disabled,
20:54:58:
20:54:58: Using directshow input
20:56:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:56:01: New Scene
20:56:01: Using graphics capture
20:56:01: Using text output
20:56:01: ------------------------------------------
20:56:01: device: Dxtory Video 1,
20:56:01: device id (null),
20:56:01: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 400000-400000, fourCC: 00000000
20:56:01: audio device: Disable,
20:56:01: audio device id Disabled,
20:56:01:
20:56:01: Using directshow input
20:56:01: device: Professional financial camera,
20:56:01: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:56:01: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:56:01:
20:56:01: Using bitmap image
20:56:03: using memory capture
20:56:04: ------------------------------------------
20:56:04: device: Professional financial camera,
20:56:04: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:56:04: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:56:04: audio device: Disable,
20:56:04: audio device id Disabled,
20:56:04:
20:56:04: Using directshow input
20:56:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:56:13: New Scene
20:56:13: Using text output
20:56:13: Using graphics capture
20:56:13: ------------------------------------------
20:56:13: device: Professional financial camera,
20:56:13: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:56:13: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:56:13: audio device: Disable,
20:56:13: audio device id Disabled,
20:56:13:
20:56:13: Using directshow input
20:56:13: Using Monitor Capture
20:56:15: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
20:56:15: New Scene
20:56:15: ------------------------------------------
20:56:15: device: Professional financial camera,
20:56:15: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:56:15: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:56:15: audio device: Disable,
20:56:15: audio device id Disabled,
20:56:15:
20:56:15: Using directshow input
20:56:15: Using text output
20:56:15: Using bitmap image
20:56:15: Using graphics capture
20:56:15: using memory capture
20:56:17: ------------------------------------------
20:56:17: device: Professional financial camera,
20:56:17: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:56:17: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
20:56:17: audio device: Disable,
20:56:17: audio device id Disabled,
20:56:17:
20:56:17: Using directshow input
21:04:14: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:04:14: New Scene
21:04:14: Using graphics capture
21:04:14: Using text output
21:04:14: ------------------------------------------
21:04:14: device: Dxtory Video 1,
21:04:14: device id (null),
21:04:14: chosen type: RGB32, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 400000-400000, fourCC: 00000000
21:04:14: audio device: Disable,
21:04:14: audio device id Disabled,
21:04:14:
21:04:14: Using directshow input
21:04:14: device: Professional financial camera,
21:04:14: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:04:14: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
21:04:14:
21:04:14: Using bitmap image
21:04:15: using memory capture
21:04:19: ------------------------------------------
21:04:19: device: Professional financial camera,
21:04:19: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:04:19: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
21:04:19: audio device: Disable,
21:04:19: audio device id Disabled,
21:04:19:
21:04:20: ------------------------------------------
21:04:20: device: Professional financial camera,
21:04:20: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:04:20: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
21:04:20: audio device: Disable,
21:04:20: audio device id Disabled,
21:04:20:
21:04:20: Using directshow input
21:21:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
21:21:38: New Scene
21:21:38: ------------------------------------------
21:21:38: device: Professional financial camera,
21:21:38: device id \\?\usb#vid_1871&pid_0101&mi_00#7&357f046e&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:21:38: chosen type: UYVY, usingFourCC: false, res: 1280x1024 - 1280x1024, frameIntervals: 333333-10000000, fourCC: 'UYVY'
21:21:38: audio device: Disable,
21:21:38: audio device id Disabled,
21:21:38:
21:21:38: Using directshow input
21:21:38: Using text output
21:21:38: Using bitmap image
21:21:38: Using graphics capture
21:21:39: using memory capture
21:55:42: Total frames rendered: 360428, number of frames that lagged: 194 (0.05%) (it's okay for some frames to lag)
21:55:42: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:55:42: Number of times waited to send: 0, Waited for a total of 0 bytes
21:55:42: Number of b-frames dropped: 10 (0.0028%), Number of p-frames dropped: 7 (0.0019%), Total 17 (0.0047%)
21:55:42: =====Stream End: 2013-07-01, 21:55:42=================================================
04:17:36:
04:17:36: Profiler results:
04:17:36:
04:17:36: ==============================================================
04:17:36: frame - [100%] [avg time: 5.672 ms] [avg calls per frame: 1] [children: 55.7%] [unaccounted: 44.3%]
04:17:36: | scene->Preprocess - [10.8%] [avg time: 0.611 ms] [avg calls per frame: 1]
04:17:36: | video encoding and uploading - [44.9%] [avg time: 2.548 ms] [avg calls per frame: 1] [children: 44.6%] [unaccounted: 0.317%]
04:17:36: | | CopyResource - [0.141%] [avg time: 0.008 ms] [avg calls per frame: 0]
04:17:36: | | conversion to 4:2:0 - [0.0882%] [avg time: 0.005 ms] [avg calls per frame: 0]
04:17:36: | | call to encoder - [43.5%] [avg time: 2.465 ms] [avg calls per frame: 0]
04:17:36: | | sending stuff out - [0.917%] [avg time: 0.052 ms] [avg calls per frame: 0]
04:17:36:
