Need help retrieving settings
NewObsUser
So I was doing some test recording and I accidentally changed my settings. The recording was PERFECT. There was no delay if any kind or lag, and the encoding was not overloaded .
Only problem is I forgot the video output settings I had..I've been at this since 6pm. It's is now 8:17pm..I need help before I pull my hair out!
I'm in Windows using an HP Stream laptop
koala
You can look into older OBS logfiles to see what settings were used with older recordings. Don't restart OBS too often, it keeps only the last 10 logfiles and it starts a new one on every OBS start.
