Need help my OBS keeps saying failed to connect to server
iFuujin
Hi everyone, I need help on identifying what's the reason and how to fix my OBS, it keeps saying that "Failed to connect to server", I kept trying multiple times, I'm have tried both Wifi and Ethernet cable, still doing the same thing, attached are the logs for FB Live
10:18:59.654: CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
10:18:59.654: CPU Speed: 3392MHz
10:18:59.654: Physical Cores: 4, Logical Cores: 4
10:18:59.654: Physical Memory: 7125MB Total, 4427MB Free
10:18:59.654: Windows Version: 10.0 Build 19045 (release: 22H2; revision: 6093; 64-bit)
10:18:59.654: Running as administrator: false
10:18:59.655: Windows 10/11 Gaming Features:
10:18:59.655: Game DVR: On
10:18:59.655: Game Mode: Probably On (no reg key set)
10:18:59.656: Sec. Software Status:
10:18:59.657: Microsoft Defender Antivirus: enabled (AV)
10:18:59.657: Windows Firewall: disabled (FW)
10:18:59.658: Current Date/Time: 2025-07-10, 10:18:59
10:18:59.658: Browser Hardware Acceleration: true
10:18:59.658: Hide OBS windows from screen capture: false
10:18:59.658: Qt Version: 6.8.3 (runtime), 6.8.3 (compiled)
10:18:59.658: Portable mode: false
10:18:59.730: OBS 31.1.0 (64-bit, windows)
10:18:59.730: ---------------------------------
10:18:59.741: ---------------------------------
10:18:59.741: audio settings reset:
10:18:59.741: samples per sec: 48000
10:18:59.741: speakers: 2
10:18:59.741: max buffering: 960 milliseconds
10:18:59.741: buffering type: dynamically increasing
10:18:59.743: ---------------------------------
10:18:59.743: Initializing D3D11...
10:18:59.743: Available Video Adapters:
10:18:59.745: Adapter 0: Intel(R) HD Graphics
10:18:59.745: Dedicated VRAM: 1040187392 (1.0 GiB)
10:18:59.745: Shared VRAM: 838860800 (0.8 GiB)
10:18:59.745: PCI ID: 8086:0152
10:18:59.745: HAGS Status: Disabled (Default: No, Driver status: Unsupported)
10:18:59.746: Driver Version: 10.18.10.5161
10:18:59.747: output 0:
10:18:59.747: name=
10:18:59.747: pos={0, 0}
10:18:59.747: size={1600, 900}
10:18:59.747: attached=true
10:18:59.747: refresh=60
10:18:59.747: bits_per_color=8
10:18:59.747: space=RGB_FULL_G22_NONE_P709
10:18:59.747: primaries=[r=(0.000000, 0.000000), g=(0.000000, 0.000000), b=(0.000000, 0.000000), wp=(0.000000, 0.000000)]
10:18:59.747: relative_gamut_area=[709=0.000000, P3=0.000000, 2020=0.000000]
10:18:59.747: sdr_white_nits=80
10:18:59.747: nit_range=[min=0.000000, max=0.000000, max_full_frame=0.000000]
10:18:59.747: dpi=96 (100%)
10:18:59.747: id=\\?\DISPLAY#Default_Monitor#4&cee03e6&0&UID16843008#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
10:18:59.747: alt_id=\\.\DISPLAY1
10:18:59.747: Loading up D3D11 on adapter Intel(R) HD Graphics (0)
10:18:59.752: D3D11 loaded successfully, feature level used: b000
10:18:59.752: DXGI increase maximum frame latency success
10:18:59.876: ---------------------------------
10:18:59.876: video settings reset:
10:18:59.876: base resolution: 1600x900
10:18:59.876: output resolution: 1280x720
10:18:59.876: downscale filter: Bicubic
10:18:59.876: fps: 30/1
10:18:59.876: format: NV12
10:18:59.876: YUV mode: Rec. 709/Partial
10:18:59.876: NV12 texture support enabled
10:18:59.876: P010 texture support not available
10:18:59.878: Audio monitoring device:
10:18:59.878: name: Default
10:18:59.878: id: default
10:18:59.880: ---------------------------------
10:18:59.882: No AJA devices found, skipping loading AJA UI plugin
10:18:59.882: Failed to initialize module 'aja-output-ui.dll'
10:18:59.884: No AJA devices found, skipping loading AJA plugin
10:18:59.884: Failed to initialize module 'aja.dll'
10:18:59.884: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
10:18:59.886: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
10:18:59.887: Failed to load 'en-US' text for module: 'decklink-captions.dll'
10:18:59.888: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
10:18:59.893: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
10:18:59.893: Failed to initialize module 'decklink.dll'
10:18:59.902: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
10:18:59.902: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
10:18:59.902: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
10:18:59.903: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
10:18:59.903: Failed to get NVVideoEffects.dll version info size
10:18:59.904: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
10:18:59.912: [obs-browser]: Version 2.25.2
10:18:59.912: [obs-browser]: CEF Version 127.0.6533.120 (runtime), 127.145.7+g2b7d20b+chromium-127.0.6533.120 (compiled)
10:18:59.917: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
10:18:59.917: (126)
10:18:59.917: NVENC not supported
10:18:59.917: Failed to initialize module 'obs-nvenc.dll'
10:18:59.986: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.6.2 | RPC Version: 1)
10:18:59.986: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.8.3 | Qt version (run-time): 6.8.3
10:18:59.986: [obs-websocket] [obs_module_load] Linked ASIO Version: 103200
10:18:59.986: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
10:18:59.994: [obs-websocket] [obs_module_load] Module loaded.
10:19:00.000: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
10:19:00.011: [obs-teleport] version: 0.7.4
10:19:00.012: ---------------------------------
10:19:00.012: Loaded Modules:
10:19:00.012: obs-teleport.dll
10:19:00.012: win-wasapi.dll
10:19:00.012: win-dshow.dll
10:19:00.012: win-capture.dll
10:19:00.012: vlc-video.dll
10:19:00.012: text-freetype2.dll
10:19:00.012: rtmp-services.dll
10:19:00.012: obs-x264.dll
10:19:00.012: obs-websocket.dll
10:19:00.012: obs-webrtc.dll
10:19:00.012: obs-vst.dll
10:19:00.012: obs-transitions.dll
10:19:00.012: obs-text.dll
10:19:00.012: obs-qsv11.dll
10:19:00.012: obs-outputs.dll
10:19:00.012: obs-filters.dll
10:19:00.012: obs-ffmpeg.dll
10:19:00.012: obs-browser.dll
10:19:00.012: nv-filters.dll
10:19:00.012: image-source.dll
10:19:00.012: frontend-tools.dll
10:19:00.012: decklink-output-ui.dll
10:19:00.012: decklink-captions.dll
10:19:00.012: coreaudio-encoder.dll
10:19:00.012: Available Encoders:
10:19:00.012: Video Encoders:
10:19:00.012: - ffmpeg_svt_av1 (SVT-AV1)
10:19:00.012: - ffmpeg_aom_av1 (AOM AV1)
10:19:00.012: - obs_qsv11_v2 (QuickSync H.264)
10:19:00.012: - obs_x264 (x264)
10:19:00.012: Audio Encoders:
10:19:00.012: - ffmpeg_aac (FFmpeg AAC)
10:19:00.012: - ffmpeg_opus (FFmpeg Opus)
10:19:00.012: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
10:19:00.012: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
10:19:00.012: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
10:19:00.012: - ffmpeg_alac (FFmpeg ALAC (24-bit))
10:19:00.012: - ffmpeg_flac (FFmpeg FLAC (16-bit))
10:19:00.012: ==== Startup complete ===============================================
10:19:00.064: All scene data cleared
10:19:00.064: ------------------------------------------------
10:19:00.070: Switched to scene 'Scene'
10:19:00.070: ------------------------------------------------
10:19:00.070: Loaded scenes:
10:19:00.070: - scene 'Scene':
10:19:00.070: - source: 'Teleport' (teleport-source)
10:19:02.590: ---------------------------------
10:19:02.591: [x264 encoder: 'simple_video_stream'] preset: veryfast
10:19:02.591: [x264 encoder: 'simple_video_stream'] settings:
10:19:02.591: rate_control: CBR
10:19:02.591: bitrate: 2500
10:19:02.591: buffer size: 2500
10:19:02.591: crf: 23
10:19:02.591: fps_num: 30
10:19:02.591: fps_den: 1
10:19:02.591: width: 1280
10:19:02.591: height: 720
10:19:02.591: keyint: 60
10:19:02.591:
10:19:02.593: ---------------------------------
10:19:02.593: [FFmpeg aac encoder: 'simple_aac'] bitrate: 128, channels: 2, channel_layout: stereo, track: 1
10:19:02.593:
10:19:02.594: [rtmp stream: 'simple_stream'] Disabling network optimizations, not compatible with RTMPS
10:19:02.594: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmps://rtmp-api.facebook.com:443/rtmp/...
10:19:02.617: RTMP_Connect1, TLS_Connect failed: -0x7080
10:19:02.617: [rtmp stream: 'simple_stream'] Connection to rtmps://rtmp-api.facebook.com:443/rtmp/ failed: -2
10:19:02.617: ==== Streaming Stop ================================================
