Question / Help my settings + some help [resolved]
Karol401
What settings should i set when i have :
amd 8350 4.6ghz
16gb ram 1600mhz
7950 radeon
because i tried setting settings from "Stream Settings Estimator" but it freezes for viewers i tried different streaming servers different sites......and when i randomly alt + tab it sometimes (that square) goes from green to yellow and then right back to green......it once was on red also i guess
Karol401
Re: my settings + some help
log:
Open Broadcaster Software v0.473b (test build 6) - 64bit ( ^ω^)
CPU Name: AMD FX(tm)-8350 Eight-Core Processor
CPU Speed: 4616MHz
Physical Memory: 16298MB Total, 14780MB Free
stepping id: 0, model 2, family 15, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1680, 1050}
Windows Version: 6.2 Build 9200
Aero is Enabled
Adapter 1
Video Adapter: AMD Radeon HD 7900 Series
Video Adapter Dedicated Video Memory: 3193106432
Video Adapter Shared System Memory: 3981936640
Adapter 2
Video Adapter: Microsoft Basic Render Driver
Video Adapter Dedicated Video Memory: 0
Video Adapter Shared System Memory: 268435456
Using fixed low latency mode, factor 20
Base resolution: 1280x720
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (Realtek High Definition Audio)
Audio Encoding: MP3
bitrate: 128
Using Monitor Capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX XOP FMA4 FMA3 SSEMisalign LZCNT BMI1 TBM
x264: profile High, level 3.1
Video Encoding: x264
fps: 25
width: 1280, height: 720
preset: veryfast
CBR: no
CFR: no
max bitrate: 2600
buffer size: 2600
quality: 10
Using RTMP service: Hashd.tv
Server selection: rtmp://edge-ams1.hashd.tv/live
SO_SNDBUF was at 65536
SO_SNDBUF is now 65536
Total frames rendered: 135340, number of frames that lagged: 3 (0.00%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
Number of times waited to send: 2231, Waited for a total of 8216622 bytes
Number of b-frames dropped: 1446 (1.1%), Number of p-frames dropped: 1957 (1.4%), Total 3403 (2.5%)
x264: frame I:746 Avg QP:21.58 size:110455
x264: frame P:48952 Avg QP:24.26 size: 16193
x264: frame B:85602 Avg QP:28.75 size: 3361
x264: consecutive B-frames: 8.9% 14.8% 16.6% 59.7%
x264: mb I I16..4: 24.1% 20.2% 55.6%
x264: mb P I16..4: 3.0% 3.3% 1.8% P16..4: 23.6% 7.5% 4.3% 0.0% 0.0% skip:56.5%
x264: mb B I16..4: 0.1% 0.1% 0.1% B16..8: 4.2% 2.1% 0.7% direct: 1.4% skip:91.3% L0:33.2% L1:48.5% BI:18.2%
x264: 8x8 transform intra:36.3% inter:26.9%
x264: coded y,uvDC,uvAC intra: 66.6% 58.3% 32.4% inter: 7.1% 5.8% 1.6%
x264: i16 v,h,dc,p: 29% 30% 31% 9%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 17% 30% 7% 7% 6% 8% 6% 10%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 23% 19% 7% 8% 7% 8% 6% 8%
x264: i8c dc,h,v,p: 57% 24% 14% 5%
x264: Weighted P-Frames: Y:0.1% UV:0.0%
x264: kb/s:1718.62
Profiler results:
frame - [100%] [avg time: 2.735 ms] [avg calls per frame: 1] [children: 87.8%] [unaccounted: 12.2%]
| scene->Preprocess - [6.65%] [avg time: 0.182 ms] [avg calls per frame: 1]
| video encoding and uploading - [81.1%] [avg time: 2.219 ms] [avg calls per frame: 1] [children: 49%] [unaccounted: 32.1%]
| | CopyResource - [0.439%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.183%] [avg time: 0.005 ms] [avg calls per frame: 0]
| | call to encoder - [47.9%] [avg time: 1.309 ms] [avg calls per frame: 0]
| | sending stuff out - [0.548%] [avg time: 0.015 ms] [avg calls per frame: 0]
hilalpro
whats your upload speed ? use a tool called shaper probe to know more accurately about your upload speed.
hilalpro
try these settings, fps at 30
bitrate and buffsize at 2432
disable low latency mode from advanced settings.
hilalpro
well just incase always keep it off, also disable "minimze network impact" from broadcasting settings. try those settings and let me know if you're still drop frames.
Karol401
if i want 30 fps what should i set my bitrate/buffer to.....and what is "use cbr" and "use cfr"
hilalpro
yes you can find in advanced settings and it should be turned off. that bitrate i suggested should be fine for 720p 30 fps actually unless you're doing like arcing games or heavy motion games then you might wanna lower the quality to 8.
cbr is constant bitrate. cfr is constant frame rate. leave those off unless you have a specific reason to use them.
Karol401
and what should i stream to in your opinion...twitch.tv or hashd.tv......and what should my preset be?
hilalpro
imo both are a really good go. pick the other if one gives you viewer problems if both seem fine go for the one that get you more viewers. as for the preset "faster" is good for those settings.
Karol401
Ok i think i am going to order crysis 3 tommorow.....so i want to be prepared.....what should i set my settings to if i want to stream it cause there are a lot of streamers for lol so i want to stream somethink that most streamers dont stream.
Karol401
ok i tried to stream with game capture but i have black screen on stream....what could be the problem?
Lain
Lain
Your stream was working fine when you used the latest version, it was just black when you alt-tabbed out of the game. It can't capture the game if you're alt-tabbed out of it, so I can see how you got that confusion.
Karol401
no it was completely black even when not alt tabed (viewer said that) but i got it fixed thx.....now i would like to know one last think.....what should my bitrate be if i want to have 720p 60 fps or 1050p 30-60 fps (dont know if my pc can take last option) but i just want to know.....thanks in advance
