TeeKay0649
So I have not used my PC for a good 3 months.
Pre-changes:
The software used to run fine, but when I started launching it, the issue suddenly appeared.
The launcher already had admin privileges, so it asked me whether I want to make changes to my PC. I clicked "Yes."
The mouse would have a little loading circle next to it for a brief 3~5 seconds, and then there would be no windows displayed.
I started to launch it again with a Task Manager open. It appeared on the Task Processes for 1~2 second before disappearing completely.
Post-changes:
I have deleted the entirety of the "OBS" folder in its directory and reinstalled the launcher.
I have already tried uninstalling & reinstalling it multiple times.
I have tried restarting my computer numerous times.
I have tried previous versions (28.1.2, 27.2.4 etc) that are NOT the current version of the OBS(29.2).
I have whitelisted OBS.exe in its list of allowed apps.
21:37:33.915: CPU Name: Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz
21:37:33.915: CPU Speed: 2904MHz
21:37:33.915: Physical Cores: 6, Logical Cores: 6
21:37:33.915: Physical Memory: 16317MB Total, 12059MB Free
21:37:33.915: Windows Version: 10.0 Build 19045 (release: 2009; revision: 2728; 64-bit)
21:37:33.915: Running as administrator: true
21:37:33.915: Aero is Enabled (Aero is always on for windows 8 and above)
21:37:33.915: Windows 10 Gaming Features:
21:37:33.915: Game Bar: On
21:37:33.915: Game DVR: On
21:37:33.915: Game DVR Background Recording: Off
21:37:33.918: Sec. Software Status:
21:37:33.919: AhnLab V3 Lite: enabled (AV)
21:37:33.919: Microsoft Defender Antivirus: disabled (AV)
21:37:33.920: Windows Firewall: enabled (FW)
21:37:33.920: Current Date/Time: 2023-04-15, 21:37:33
21:37:33.920: Browser Hardware Acceleration: true
21:37:33.920: Hide OBS windows from screen capture: false
21:37:33.920: Qt Version: 5.15.2 (runtime), 5.15.2 (compiled)
21:37:33.920: Portable mode: false
21:37:34.326: OBS 27.2.4 (64-bit, windows)
21:37:34.326: ---------------------------------
21:37:34.327: ---------------------------------
21:37:34.327: audio settings reset:
21:37:34.327: samples per sec: 48000
21:37:34.327: speakers: 2
21:37:34.348: ---------------------------------
21:37:34.348: Initializing D3D11...
21:37:34.348: Available Video Adapters:
21:37:34.352: Adapter 0: NVIDIA GeForce GTX 1660 SUPER
21:37:34.352: Dedicated VRAM: 1975517184
21:37:34.352: Shared VRAM: 4260335616
21:37:34.352: PCI ID: 10de:21c4
21:37:34.353: Driver Version: 31.0.15.2756
21:37:34.353: output 0:
21:37:34.353: name=S24F350
21:37:34.353: pos={0, 0}
21:37:34.353: size={1920, 1080}
21:37:34.353: attached=true
21:37:34.353: refresh=60
21:37:34.353: space=RGB_FULL_G22_NONE_P709
21:37:34.353: sdr_white_nits=80
21:37:34.353: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
21:37:34.357: Loading up D3D11 on adapter NVIDIA GeForce GTX 1660 SUPER (0)
Pre-changes:
Post-changes:
