BlondiHDR
Hi board !
I have a problem that I haven't been able to solve for weeks, after trying a lot of things.
When I play MW2 (Multi or Warzone) with OBS on, the game crashes after a few minutes, or immediately, with a steam code 0x0000005 (0) N.
The game only crashes when OBS is on, even without streaming or recording.
Here is what I tried:
- Minimize OBS instead of leaving it open on a secondary screen.
- Play in 60HZ + screen set to 60HZ.
- Disconnect the secondary screen (see configuration below).
- Clean up my scene as much as possible (leave only game capture).
- Launch OBS in administrator mode.
- Encode in X264 or in NVENC H264 (+ low quality).
- Close all other programs.
- Play MW2 in 600x800px and very low quality.
- Remove all overlays on the game.
- Lots of things I don't remember.
- Rage, Alt+F4 and go to sleep.
My setup:
- ASUS TUF RTX 3090 24G OC Edition
- Intel i9 13900K
- Asus ROG Maximus Z690 Extreme
- Kingston Furry Beast 64Go 5600
- Kingston Furry Renegade SSD M2 2To
- Samsung Odyssey NEO G9 (Primary - 5120x1440 240hz)
- LG 22EA53VQ (Secondary - 1920x1080 60hz)
- Full EKWB Custom Watercooling
- Elgato StreamDeck XL
- Logitech G915 Tactile
- Logitech G502
- Logitech Streamcam
- Logitech G29
Logs of a crash:
https://obsproject.com/tools/analyzer?log_url=https://obsproject.com/logs/XbYFimJVIvfCwmWM#logURL
Thanks in advance for your help ! :)
  • 2022-12-27 18-33-27.txt
BlondiHDR
Thank you for your answers !
Does it crash in fullscreen borderless with OBS running game capture?
Did you try window capture or Desktop Capture as well?
I tried :
- "exclusive full screen" and "game capture".
- "exclusive full screen" and "window capture".
- "full windowed screen (without borders)" and "window capture".
I'll try "windowed full screen (no borders)" and "game capture".
Try old version OBS Studio 27.2.4 and add screenshot you setting output
I will try and let you know.
Thanks again !
BlondiHDR
Guys it worked pretty well !
LOGS :
https://obsproject.com/tools/analyzer?log_url=https://obsproject.com/logs/FvPaIMnXsI6QkKUR#logURL
I played 20 minutes without crashing (about 3 games on shipment), whereas before I couldn't do a full one.
I kept the 522.25 driver from NVIDIA and only put "game capture" in my OBS scene.
I will gradually try:
- Create scenes with the minimum required (Webcam, logo, follow alert, last follower).
- Update the driver.
- Reinstall the latest version of OBS starting on an empty and clean scene.
If I encounter a new crash, I'll backtrack.
I will let you know if I have any new problems or if everything works, for people who have the same problem.
Thanks again guys!
Mr Faust
Хлопці, це спрацювало досить добре!
ЛОГИ:
Я грав 20 хвилин без збоїв (приблизно 3 ігри на відправці), тоді як раніше я не міг зробити повну.
Я зберіг драйвер 522.25 від NVIDIA і поставив лише «захоплення гри» у своїй сцені OBS.
Поступово пробуватиму:
- Створюйте сцени з необхідним мінімумом (веб-камера, логотип, сповіщення про підписку, останній підписник).
- Оновити драйвер.
- Перевстановіть останню версію OBS, починаючи з порожньої та чистої сцени.
Якщо я зіткнуся з новим збоєм, я повернуся назад.
Я повідомлю вам, якщо у мене виникнуть нові проблеми або якщо все працює, для людей, які мають таку ж проблему.
Ще раз дякую, хлопці!
It's great, but you're installed 32-bit version, please install 64-bit version and try upgrade version 28.03. When I upgrade last version I have problem often is crash OBS. when I downgrade its work. Now I'm testing OBS for stable
BlondiHDR
Okay guys it works !
I filled in my OBS scenes, installed the 64 bit version and left NVIDIA version 522.25.
I had time to make 4 games on Shipment and a top 3 on Warzone.
It will stay that way as long as it works!
You can see the result here, and if this thread helped you, drop a Follow!
Mr Faust
It's great that you solved your problem! I have it working stably on version 28.0.3 so far!
happy holidays!
