Bug Report Mouse Cursor issue
aligator
Cropping monitor capture from the lower right corner causes the default mouse cursor to appear as a black box (size changing depending on how much you are cropping). Other cursors (like over-text or button cursors) don't appear at all. I'm using Windows 8.1 Pro. Additional info available if you just tell me what is needed.
video of the issue: http://youtu.be/GFV1iGYf8yA
  • 2014-02-12-2232-50.log
Lain
Lain
I didn't see your mouse at all in that video. Or am I crazy? I think I know what's going on here though. Thank yo ufor pointing it out.
aligator
The mouse shows up in the first 5 seconds when there is no cropping, when the cropping starts the default cursor turns into that black box, and the over text cursor is just not there, I also tried to change the cursor windows was using, one of them appeared as a white box instead of a black box.
I also tried this with game capture on League of Legends, the cursor did not appear at all there (no black box either)
You're welcome, hopefully it's an easy fix :)
