Bug Report Monitors blinking on and off during monitor capture
Fogazi
Got this weird issue when trying to use monitor capture, as soon as I select preview/record both my monitors start flashing?
Have searched the forums/google with no one else having a similar problem.
Doesn't matter which monitor I select as it does it for both.
Now the reason I chose to use monitor capture is because I cannot get window capture to show popup/dialogue windows that display during use of certain programs.
Have updated graphics drivers and tried both 32 and 64 bit platforms.
I am running Windows 10 Tech Preview which I think may be the issue.
Cheers,
Here is the latest log file:
13:45:12: Open Broadcaster Software v0.638b - 64bit ( ^ω^)
13:45:12: -------------------------------
13:45:12: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
13:45:12: CPU Speed: 3293MHz
13:45:12: Physical Memory: 12233MB Total, 10271MB Free
13:45:12: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
13:45:12: monitor 1: pos={0, 0}, size={1920, 1080}
13:45:12: monitor 2: pos={1920, 0}, size={1680, 1050}
13:45:12: Windows Version: 6.2 Build 9200
13:45:12: Aero is Enabled
13:45:12: OBS Modules:
13:45:12: Base Address Module
13:45:12: 000000004A780000 OBS.exe
13:45:12: 000000000D0F0000 OBSApi.dll
13:45:12: 000000000D0B0000 DShowPlugin.dll
13:45:12: 000000000D070000 GraphicsCapture.dll
13:45:12: 0000000012B90000 LogiLCD.dll
13:45:12: 000000000D040000 NoiseGate.dll
13:45:12: 000000000CED0000 PSVPlugin.dll
13:45:12: 0000000011970000 scenesw.dll
13:45:12: ------------------------------------------
13:45:12: Adapter 1
13:45:12: Video Adapter: AMD Radeon R9 200 Series
13:45:12: Video Adapter Dedicated Video Memory: 3202506752
13:45:12: Video Adapter Shared System Memory: 4026531840
13:45:12: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
13:45:12: Video Adapter Output 2: pos={1920, 0}, size={1680, 1050}, attached=true
13:45:12: =====Stream Start: 2014-12-23, 13:45:12===============================================
13:45:12: Multithreaded optimizations: On
13:45:12: Base resolution: 1920x1080
13:45:12: Output resolution: 1280x720
13:45:12: Loading up D3D10 on AMD Radeon R9 200 Series (Adapter 1)...
13:45:12: Audio Format: 48000 Hz
13:45:12: Audio Channels: 2 Ch
13:45:12: Playback device Default
13:45:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
13:45:12: Global Audio time adjust: 0
13:45:12: Using 5.1 speaker setup
13:45:12: Using auxilary audio input: Microphone (Realtek High Definition Audio)
13:45:12: Mic time offset: 0
13:45:12: Audio Encoding: AAC
13:45:12: bitrate: 128
13:45:12: Using Monitor Capture
13:45:12: Scene buffering time set to 700
13:45:12: Video Encoding: x264
13:45:12: fps: 30
13:45:12: width: 1280, height: 720
13:45:12: preset: veryfast
13:45:12: profile: high
13:45:12: keyint: 250
13:45:12: CBR: yes
13:45:12: CFR: yes
13:45:12: max bitrate: 3000
13:45:12: buffer size: 3000
13:45:23: FlushBufferedVideo: Flushing 5 packets over 133 ms
13:45:23: Total frames encoded: 306, total frames duplicated: 53 (17.32%)
13:45:23: Total frames rendered: 294, number of late frames: 11 (3.74%) (it's okay for some frames to be late)
13:45:23:
13:45:23: Profiler time results:
13:45:23:
13:45:23: ==============================================================
13:45:23: video thread frame - [100%] [avg time: 8.864 ms] [children: 74.8%] [unaccounted: 25.2%]
13:45:23: | scene->Preprocess - [67.4%] [avg time: 5.971 ms]
13:45:23: | GPU download and conversion - [7.43%] [avg time: 0.659 ms] [children: 7.03%] [unaccounted: 0.406%]
13:45:23: | | flush - [4.57%] [avg time: 0.405 ms]
13:45:23: | | CopyResource - [2.09%] [avg time: 0.185 ms]
13:45:23: | | conversion to 4:2:0 - [0.372%] [avg time: 0.033 ms]
13:45:23: Convert444Threads - [100%] [avg time: 0.454 ms] [children: 98.7%] [unaccounted: 1.32%]
13:45:23: | Convert444toNV12 - [98.7%] [avg time: 0.448 ms]
13:45:23: encoder thread frame - [100%] [avg time: 1.293 ms] [children: 0.541%] [unaccounted: 99.5%]
13:45:23: | sending stuff out - [0.541%] [avg time: 0.007 ms]
13:45:23:
13:45:23:
13:45:23: Profiler CPU results:
13:45:23:
13:45:23: video thread frame - [cpu time: avg 0.425 ms, total 125 ms] [avg calls per frame: 1]
13:45:23: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
13:45:23: | GPU download and conversion - [cpu time: avg 0.106 ms, total 31.25 ms] [avg calls per frame: 1]
13:45:23: | | flush - [cpu time: avg 0.106 ms, total 31.25 ms] [avg calls per frame: 1]
13:45:23: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
13:45:23: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
13:45:23: Convert444Threads - [cpu time: avg 0.229 ms, total 125 ms] [avg calls per frame: 2]
13:45:23: | Convert444toNV12 - [cpu time: avg 0.229 ms, total 125 ms] [avg calls per frame: 2]
13:45:23: encoder thread frame - [cpu time: avg 0.571 ms, total 171.875 ms] [avg calls per frame: 1]
13:45:23: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
13:45:23:
13:45:23: =====Stream End: 2014-12-23, 13:45:23=================================================
Last game capture log:
2014-12-22, 22:37:11: we're booting up:
22:37:11: CaptureThread: attached to process EliteOCR.exe
22:37:11: DXGI Present
22:37:11: GL Present
22:37:11: DirectDraw capture: Windows 8 not supported yet
22:37:11: (half life scientist) everything.. seems to be in order
Last Game Capture Log:
Fogazi
Derp, I just seen two near identical posts down the list with a fix.
With windows 10, run OBS in Win 7 compat mode, works great....
