Monitor and Output mutes Output
DrewSunn
Ever since OBS 32 my monitoring device has been broken. It works fine on my end, and everything outside of OBS is perfect, but when a source is set to "Monitor and Output" it instead acts as though it is set to "Monitor Only (mute output)." I was able to fix it for a time by setting my monitoring device to something else other than what it was set to prior to the update (it was on "Cable-D" so I set it to "Cable-C" to fix it) however that is now not working as well. I have changed almost nothing since the update other than trying to make Cable-C work as the monitoring device. I posted in a different forum about this issue, but was not given a solution beyond "mute the source and then unmute it" which did not work. The only solution I can think of is to use a plugin by Exeldro to monitor my audio which would be insanely inconvenient at this point. Others have been having similar issues, as I said there was another forum post, and as I was typing this live other people in chat said they had a similar issue that still has yet to be solved.
I understand this is kind of a niche thing, most streamers don't use a separate monitoring device and instead have all audio broadcasting, which is probably why there isn't a louder outcry about it, however for those that this applies it is insanely inconvenient to lose access to a monitoring device that you've used for years.
Here's a log of the still on-going stream: https://obsproject.com/logs/lo2VuEbV66DOkKMB
I am on Windows 10 still.
