Dave Wilson
So, I've had this problem for a while now and since the team is so good at updates I had hoped it will eventually be addressed or resolved. However, after the recent update it's still an issue for me so I've decided to report it in case it's not mentioned before.
Quite often while streaming my Monitor 1 capture will show up as black on launching OBS, or when switching back to the Scene using it, from another scene. Also, at times, randomly it seems, the Monitor 1 screen will freeze/not update though Web cam overlays are still running fine and ALL audio is still broadcasting. I need to switch to another scene for a moment and then switch back for it start updating again.This DOES affect streams.
Here is the log file after applying the update yet still launching with black Monitor 1.
https://gist.github.com/9cb0acd9ac4e84970fa4c47c31ed36a4
Thanks.
Thanks.
