Mirabox Capture card does not show as a device when i try to do video capture.
LittleDrasnian
Mirabox Capture card does not show as a device when i try to do video capture. I do the "new source" select "Video Capture Device" and there are no devices to select. Any help?
LittleDrasnian
Video Capture Device - show only DirectShow device, install correct driver.
Drivers seem to be installed correctly, no idea what you mean by show only DirectShow device.
LittleDrasnian
Any other software like VLC see your card ?
well i did not have vlc, looked into that, i got errors, looked into those errors, and fixed them, which makes it so i have the option to at least see my device. Getting the black screen error, but theres been other threads about it. Thank you
