I've been having this problem repeatedly recently.
The microphone meter responds and goes up and down when I speak as per usual, however the stream gets no audio output of my microphone. The audio of my desktop goes through without a problem though, it's just my microphone.
Just to confirm, I mean this meter:
Now I assume this is due to my odd audio setup, I'm currently routing my microphone through Adobe Audition and Virtual Audio Cable and then into OBS so that I can apply realtime effects on my voice. I'm also using QPC timestamps to try and fix the sync between my webcam and voice.
Here's a pastebin of one of my logs: http://pastebin.com/83Uw4D6w
Note that I've edited it because there is thousands of this line in it, you can see the note on line 93:
The problem doesn't happen all the time but it's incredibly annoying because I have no way to tell if it's happening or not before I go live. I have to wait for someone to tell me it's messed up! D:
Thanks for your time,
Bluesatin.
14:46:42: Audio timestamp for device '[VAC] Line 1 In (Virtual Audio Cable)' was behind target timestamp by 3518
Bluesatin.
