13:27:55.236: CPU Name: Intel(R) Xeon(R) CPU E5-1650 0 @ 3.20GHz
13:27:55.236: CPU Speed: 3200MHz
13:27:55.236: Physical Cores: 6, Logical Cores: 12
13:27:55.236: Physical Memory: 16298MB Total, 13677MB Free
13:27:55.236: Windows Version: 6.1 Build 7601 (revision: 23572; 64-bit)
13:27:55.237: Running as administrator: true
13:27:55.237: Aero is Disabled
13:27:55.237: Portable mode: false
13:27:55.246: OBS 18.0.1 (64bit, windows)
13:27:55.246: ---------------------------------
13:27:55.246: audio settings reset:
13:27:55.246: samples per sec: 48000
13:27:55.246: speakers: 2
13:27:55.247: ---------------------------------
13:27:55.247: Initializing D3D11..
13:27:55.247: Available Video Adapters:
13:27:55.248: Adapter 1: NVIDIA GeForce GTX 980
13:27:55.248: Dedicated VRAM: 4204462080
13:27:55.248: Shared VRAM: 3981838336
13:27:55.248: output 1: pos={0, 0}, size={1920, 1080}, attached=true
13:27:55.248: output 2: pos={1920, 0}, size={1440, 900}, attached=true
13:27:55.250: Loading up D3D11 on adapter NVIDIA GeForce GTX 980 (0)
13:27:55.260: D3D11 loaded sucessfully, feature level used: 45056
13:27:56.310: ---------------------------------
13:27:56.310: video settings reset:
13:27:56.310: base resolution: 1920x1080
13:27:56.310: output resolution: 1280x720
13:27:56.310: downscale filter: Lanczos
13:27:56.310: fps: 60/1
13:27:56.310: format: NV12
13:27:56.311: Audio monitoring device:
13:27:56.311: name: Default
13:27:56.311: id: default
13:27:56.311: ---------------------------------
13:27:56.312: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
13:27:56.313: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
13:27:56.313: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
13:27:56.322: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
13:27:56.322: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
13:27:56.322: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
13:27:56.322: Failed to load 'en-US' text for module: 'obs-browser.dll'
13:27:56.322: [browser_source: 'Version: 1.29.0']
13:27:56.323: NVENC supported
13:27:56.360: Couldn't find VLC installation, VLC video source disabled
13:27:56.364: No blackmagic support
13:27:56.368: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
13:27:56.369: ---------------------------------
13:27:56.369: Loaded Modules:
13:27:56.369: win-wasapi.dll
13:27:56.369: win-mf.dll
13:27:56.369: win-dshow.dll
13:27:56.369: win-decklink.dll
13:27:56.369: win-capture.dll
13:27:56.369: vlc-video.dll
13:27:56.369: text-freetype2.dll
13:27:56.369: rtmp-services.dll
13:27:56.369: obs-x264.dll
13:27:56.369: obs-vst.dll
13:27:56.369: obs-transitions.dll
13:27:56.369: obs-text.dll
13:27:56.369: obs-qsv11.dll
13:27:56.369: obs-outputs.dll
13:27:56.369: obs-filters.dll
13:27:56.369: obs-ffmpeg.dll
13:27:56.369: obs-browser.dll
13:27:56.369: image-source.dll
13:27:56.369: frontend-tools.dll
13:27:56.369: enc-amf.dll
13:27:56.369: coreaudio-encoder.dll
13:27:56.369: ==== Startup complete ===============================================
13:27:56.370: All scene data cleared
13:27:56.370: ------------------------------------------------
13:27:56.382: WASAPI: Device 'Speakers (High Definition Audio Device)' initialized
13:27:56.391: WASAPI: Device 'Microphone (High Definition Audio Device)' initialized
13:27:56.414: ---------------------------------
13:27:56.414: [DShow Device: 'Video Capture Device'] settings updated:
13:27:56.414: video device: AVerMedia HD Capture C985 Bus 3
13:27:56.414: video path: \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&107a8ef5&0&0018#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a}
13:27:56.414: resolution: 1280x720
13:27:56.414: fps: 60.00 (interval: 166666)
13:27:56.414: format: YV12
13:27:56.416: using video device audio: yes
13:27:56.416: sample rate: 48000
13:27:56.416: channels: 2
13:27:56.416: audio type: Capture
13:27:56.477: adding 21 milliseconds of audio buffering, total audio buffering is now 21 milliseconds
13:27:56.546: Switched to scene 'Scene'
13:27:56.546: ------------------------------------------------
13:27:56.546: Loaded scenes:
13:27:56.546: - scene 'Scene':
13:27:56.546: - source: 'Video Capture Device' (dshow_input)
13:27:56.546: - filter: 'Color Correction' (color_filter)
13:27:56.546: - source: 'Game Capture' (game_capture)
13:27:56.546: - source: 'Display Capture' (monitor_capture)
13:27:56.546: - source: 'Webcam' (dshow_input)
13:27:56.546: - source: 'Chat' (browser_source)
13:27:56.546: - source: 'Donor' (browser_source)
13:27:56.546: - source: 'Goal' (browser_source)
13:27:56.546: - source: 'Follower' (browser_source)
13:27:56.546: - scene 'Scene 2':
13:27:56.956: ---------------------------------
13:27:56.956: [DShow Device: 'Webcam'] settings updated:
13:27:56.956: video device: USB Video Device
13:27:56.956: video path: \\?\usb#vid_046d&pid_0825&mi_00#7&e3d04dd&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
13:27:56.956: resolution: 1280x720
13:27:56.956: fps: 30.00 (interval: 333333)
13:27:56.956: format: MJPEG
13:27:56.956: DShow: HDevice::ConnectPins: failed to connect pins (0x80040207): The owner SID on a per-user subscription doesn't exist
13:27:56.956:
13:28:03.757: adding 21 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
13:28:11.644: [game-capture: 'Game Capture'] attempting to hook fullscreen process: maxpayne2.exe
13:28:11.645: [game-capture: 'Game Capture'] using helper (direct hook)
13:28:11.645: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
13:28:15.661: [game-capture: 'Game Capture'] attempting to hook fullscreen process: maxpayne2.exe
13:28:15.669: [game-capture: 'Game Capture'] d3d8 memory capture successfull
13:28:15.678: [game-capture: 'Game Capture'] memory capture successful
13:30:57.217: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
13:30:57.218: [game-capture: 'Game Capture'] capture stopped
13:30:58.939: ==== Shutting down ==================================================
13:30:58.941: Switched to scene '(null)'
13:31:00.007: WASAPI: Device 'Speakers (High Definition Audio Device)' Terminated
13:31:00.009: WASAPI: Device 'Microphone (High Definition Audio Device)' Terminated
13:31:00.011: All scene data cleared
13:31:00.011: ------------------------------------------------
13:31:00.042: Freeing OBS context data
13:31:00.125: == Profiler Results =============================
13:31:00.125: run_program_init: 1344.47 ms
13:31:00.125: ┣OBSApp::AppInit: 1.042 ms
13:31:00.125: ┃ ┗OBSApp::InitLocale: 0.684 ms
13:31:00.125: ┗OBSApp::OBSInit: 1340.08 ms
13:31:00.125: ┣obs_startup: 0.56 ms
13:31:00.125: ┗OBSBasic::OBSInit: 1321.69 ms
13:31:00.125: ┣OBSBasic::InitBasicConfig: 0.205 ms
13:31:00.125: ┣OBSBasic::ResetAudio: 0.118 ms
13:31:00.125: ┣OBSBasic::ResetVideo: 1064.77 ms
13:31:00.125: ┣OBSBasic::InitOBSCallbacks: 0.003 ms
13:31:00.125: ┣OBSBasic::InitHotkeys: 0.032 ms
13:31:00.125: ┣obs_load_all_modules: 57.247 ms
13:31:00.125: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.195 ms
13:31:00.125: ┃ ┣obs_init_module(enc-amf.dll): 0.106 ms
13:31:00.125: ┃ ┣obs_init_module(frontend-tools.dll): 1.315 ms
13:31:00.125: ┃ ┣obs_init_module(image-source.dll): 0.003 ms
13:31:00.125: ┃ ┣obs_init_module(obs-browser.dll): 0.044 ms
13:31:00.125: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.372 ms
13:31:00.125: ┃ ┣obs_init_module(obs-filters.dll): 0.006 ms
13:31:00.125: ┃ ┣obs_init_module(obs-outputs.dll): 0.004 ms
13:31:00.125: ┃ ┣obs_init_module(obs-qsv11.dll): 34.038 ms
13:31:00.125: ┃ ┣obs_init_module(obs-text.dll): 0.219 ms
13:31:00.125: ┃ ┣obs_init_module(obs-transitions.dll): 0.003 ms
13:31:00.125: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
13:31:00.125: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
13:31:00.125: ┃ ┣obs_init_module(rtmp-services.dll): 0.214 ms
13:31:00.125: ┃ ┣obs_init_module(text-freetype2.dll): 0.013 ms
13:31:00.125: ┃ ┣obs_init_module(vlc-video.dll): 0.022 ms
13:31:00.125: ┃ ┣obs_init_module(win-capture.dll): 0.036 ms
13:31:00.125: ┃ ┣obs_init_module(win-decklink.dll): 3.596 ms
13:31:00.125: ┃ ┣obs_init_module(win-dshow.dll): 2.616 ms
13:31:00.125: ┃ ┣obs_init_module(win-mf.dll): 0.628 ms
13:31:00.125: ┃ ┣obs_init_module(win-wasapi.dll): 0.004 ms
13:31:00.125: ┃ ┗reset_win32_symbol_paths: 0.093 ms
13:31:00.125: ┣OBSBasic::ResetOutputs: 0.302 ms
13:31:00.125: ┣OBSBasic::CreateHotkeys: 0.149 ms
13:31:00.125: ┣OBSBasic::InitService: 0.059 ms
13:31:00.125: ┣OBSBasic::InitPrimitives: 0.226 ms
13:31:00.125: ┗OBSBasic::Load: 177.35 ms
13:31:00.125: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.004 ms, max=138.705 ms, 99th percentile=0.035 ms, 99.9587% below 25 ms
13:31:00.125: audio_thread(Audio): min=0 ms, median=0.038 ms, max=0.289 ms, 99th percentile=0.08 ms
13:31:00.125: obs_video_thread(16.6667 ms): min=0.189 ms, median=1.825 ms, max=198.351 ms, 99th percentile=2.46 ms, 99.9636% below 16.667 ms
13:31:00.125: ┣tick_sources: min=0.001 ms, median=1.259 ms, max=189.475 ms, 99th percentile=1.722 ms
13:31:00.125: ┣render_displays: min=0 ms, median=0.28 ms, max=56.02 ms, 99th percentile=0.421 ms
13:31:00.125: ┗output_frame: min=0.188 ms, median=0.283 ms, max=4.338 ms, 99th percentile=0.411 ms
13:31:00.125: ┣gs_context(video->graphics): min=0.06 ms, median=0.106 ms, max=4.12 ms, 99th percentile=0.152 ms
13:31:00.125: ┃ ┣render_video: min=0.015 ms, median=0.038 ms, max=0.215 ms, 99th percentile=0.051 ms
13:31:00.125: ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.021 ms, max=0.149 ms, 99th percentile=0.028 ms
13:31:00.125: ┃ ┃ ┣render_output_texture: min=0.002 ms, median=0.007 ms, max=0.075 ms, 99th percentile=0.01 ms
13:31:00.125: ┃ ┃ ┣render_convert_texture: min=0 ms, median=0.007 ms, max=0.097 ms, 99th percentile=0.009 ms
13:31:00.125: ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.002 ms, max=0.035 ms, 99th percentile=0.003 ms
13:31:00.125: ┃ ┣download_frame: min=0 ms, median=0.002 ms, max=3.88 ms, 99th percentile=0.003 ms
13:31:00.125: ┃ ┗gs_flush: min=0.032 ms, median=0.064 ms, max=1.038 ms, 99th percentile=0.095 ms
13:31:00.125: ┗output_video_data: min=0.141 ms, median=0.174 ms, max=0.833 ms, 99th percentile=0.271 ms
13:31:00.125: video_thread(video): min=0 ms, median=0.001 ms, max=0.009 ms, 99th percentile=0.002 ms
13:31:00.125: =================================================
13:31:00.125: == Profiler Time Between Calls ==================
13:31:00.125: obs_hotkey_thread(25 ms): min=24.768 ms, median=25.39 ms, max=164.12 ms, 99.8762% within ±2% of 25 ms (0% lower, 0.123848% higher)
13:31:00.125: obs_video_thread(16.6667 ms): min=6.69 ms, median=16.667 ms, max=198.362 ms, 99.9091% within ±2% of 16.667 ms (0.0545405% lower, 0.0363603% higher)
13:31:00.136: Number of memory leaks: 33
