Bug Report Magic changing resolutions
Flat_Battery
Hi guys
I am having some problems that I may need to list. They may even be connected.
1. All of the sources changed resolution after closing and re-openning OBS. Zoomed way in to the top left. Cant edit back to position as they are "off screen"
2. Chrome key capture stopped working. Was grabbing loads of different greys and browns but not the chroma key green of SubAlert
3. Closed and reopened OBS. The resolution of the preview scree changed (see attached - untitled.png) .... for normal screen seen attached untitled2.png (taken from previous recording through VLC)
I now on Windows 10. Did not have any of these issues before update to it.
Hope these help. Lemme know if you need anything else
Flat_Battery
Ahhhh much better! Fantico! Thank you ever so much. All sorted now. Didn't change it myself but now I know how to sort it out if it does it again. Many thanks :D
