My bad for posting in here instead of the Questions and Help section.
Hi, so recently I've been trying to stream some TF2 for my friends and I'm running into a really unusual problem. For the livestream viewers and whenever I "Preview Stream," I always see that the stream is almost at a constant <20 FPS and becomes really choppy like this:
However, even while the stream is choppy for my viewers and whenever I preview it, I don't have any sort of FPS drop or lag on my end. Here's another picture taken inside the game within the exact same moment. The FPS in the livestream is inconsistent with my actual in-game FPS:
Even more unusual: watching the recordings of my stream show very little to almost none of the FPS problems my viewers were getting when it was live.
I don't think it's my upload speed either. My internet is way above average than most streamers, and I have set the broadcasting server to Dallas so it should have nothing to do with that. The thing is, changing my bitrate really high or really low doesn't affect the livestream's choppiness.
Here are the logs as well; apologies if they're a little long. I was trying to change a few settings to try and fix this problem for my stream viewers, but it seems like regardless of the settings I change, the livestream will be at low FPS for viewers and whenever I use the "Preview Stream" button. I run TF2 in windowed mode with no border; I was streaming using Game Capture.
I don't know what to do; if you guys need more information from me I'll try to provide some. :(
18:36:16: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
18:36:16: -------------------------------
18:36:16: CPU Name: Intel(R) Core(TM) i7 CPU 980 @ 3.33GHz
18:36:16: CPU Speed: 4015MHz
18:36:16: Physical Memory: 12279MB Total, 8914MB Free
18:36:16: stepping id: 2, model 12, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 12, total cores 6
18:36:16: monitor 1: pos={0, 0}, size={1920, 1080}
18:36:16: monitor 2: pos={1920, 0}, size={1920, 1080}
18:36:16: Windows Version: 6.1 Build 7601 S
18:36:16: Aero is Disabled
18:36:16: OBS Modules:
18:36:16: Base Address Module
18:36:16: 000000003F880000 OBS.exe
18:36:16: 00000000E9DD0000 OBSApi.dll
18:36:16: 00000000F17A0000 DShowPlugin.dll
18:36:16: 00000000F1770000 GraphicsCapture.dll
18:36:16: 00000000F1750000 NoiseGate.dll
18:36:16: ------------------------------------------
18:36:16: Adapter 1
18:36:16: Video Adapter: NVIDIA GeForce GTX 670
18:36:16: Video Adapter Dedicated Video Memory: 2091581440
18:36:16: Video Adapter Shared System Memory: 2147479552
18:36:16: =====Stream Start: 2013-06-30, 18:36:16===============================================
18:36:16: Multithreaded optimizations: On
18:36:16: Base resolution: 1920x1080
18:36:16: Output resolution: 1920x1080
18:36:16: Loading up D3D10...
18:36:16: Playback device Default
18:36:16: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:36:16: Using 5.1 speaker setup
18:36:16: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:36:16: Audio Encoding: AAC
18:36:16: bitrate: 192
18:36:16: Using custom x264 settings: "vbv-maxbitrate=1000"
18:36:16: The custom x264 command 'vbv-maxbitrate=1000' failed
18:36:16: Video Encoding: x264
18:36:16: fps: 30
18:36:16: width: 1920, height: 1080
18:36:16: preset: veryfast
18:36:16: CBR: no
18:36:16: CFR: no
18:36:16: max bitrate: 2500
18:36:16: buffer size: 5000
18:36:16: quality: 8
18:36:17: Total frames rendered: 21, number of frames that lagged: 1 (4.76%) (it's okay for some frames to lag)
18:36:17: =====Stream End: 2013-06-30, 18:36:17=================================================
18:36:18: =====Stream Start: 2013-06-30, 18:36:18===============================================
18:36:18: Multithreaded optimizations: On
18:36:18: Base resolution: 1920x1080
18:36:18: Output resolution: 1920x1080
18:36:18: ------------------------------------------
18:36:18: Loading up D3D10...
18:36:18: Playback device Default
18:36:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:36:18: Using 5.1 speaker setup
18:36:18: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:36:18: Audio Encoding: AAC
18:36:18: bitrate: 192
18:36:18: Using graphics capture
18:36:18: Using custom x264 settings: "vbv-maxbitrate=1000"
18:36:18: The custom x264 command 'vbv-maxbitrate=1000' failed
18:36:18: Video Encoding: x264
18:36:18: fps: 30
18:36:18: width: 1920, height: 1080
18:36:18: preset: veryfast
18:36:18: CBR: no
18:36:18: CFR: no
18:36:18: max bitrate: 2500
18:36:18: buffer size: 5000
18:36:18: quality: 8
18:36:20: Total frames rendered: 32, number of frames that lagged: 1 (3.13%) (it's okay for some frames to lag)
18:36:20: =====Stream End: 2013-06-30, 18:36:20=================================================
18:36:22: =====Stream Start: 2013-06-30, 18:36:22===============================================
18:36:22: Multithreaded optimizations: On
18:36:22: Base resolution: 1920x1080
18:36:22: Output resolution: 1920x1080
18:36:22: ------------------------------------------
18:36:22: Loading up D3D10...
18:36:22: Playback device Default
18:36:22: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:36:22: Using 5.1 speaker setup
18:36:22: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:36:22: Audio Encoding: AAC
18:36:22: bitrate: 192
18:36:22: Using graphics capture
18:36:22: Using custom x264 settings: "vbv-maxbitrate=1000"
18:36:22: The custom x264 command 'vbv-maxbitrate=1000' failed
18:36:22: Video Encoding: x264
18:36:22: fps: 30
18:36:22: width: 1920, height: 1080
18:36:22: preset: veryfast
18:36:22: CBR: no
18:36:22: CFR: no
18:36:22: max bitrate: 2500
18:36:22: buffer size: 5000
18:36:22: quality: 8
18:36:23: Total frames rendered: 23, number of frames that lagged: 1 (4.35%) (it's okay for some frames to lag)
18:36:23: =====Stream End: 2013-06-30, 18:36:23=================================================
18:36:30: =====Stream Start: 2013-06-30, 18:36:30===============================================
18:36:30: Multithreaded optimizations: On
18:36:30: Base resolution: 1920x1080
18:36:30: Output resolution: 1920x1080
18:36:30: ------------------------------------------
18:36:30: Loading up D3D10...
18:36:30: Playback device Default
18:36:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:36:30: Using 5.1 speaker setup
18:36:30: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:36:30: Audio Encoding: AAC
18:36:30: bitrate: 192
18:36:30: Using graphics capture
18:36:30: Using custom x264 settings: "vbv-maxbitrate=1000"
18:36:30: The custom x264 command 'vbv-maxbitrate=1000' failed
18:36:30: Video Encoding: x264
18:36:30: fps: 30
18:36:30: width: 1920, height: 1080
18:36:30: preset: veryfast
18:36:30: CBR: no
18:36:30: CFR: no
18:36:30: max bitrate: 2500
18:36:30: buffer size: 5000
18:36:30: quality: 8
18:36:31: SharedTexCapture hooked
18:36:31: Total frames rendered: 33, number of frames that lagged: 1 (3.03%) (it's okay for some frames to lag)
18:36:31: =====Stream End: 2013-06-30, 18:36:31=================================================
18:58:49: =====Stream Start: 2013-06-30, 18:58:49===============================================
18:58:49: Multithreaded optimizations: On
18:58:49: Base resolution: 1920x1080
18:58:49: Output resolution: 1920x1080
18:58:49: ------------------------------------------
18:58:49: Loading up D3D10...
18:58:49: Playback device Default
18:58:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
18:58:49: Using 5.1 speaker setup
18:58:49: Using auxilary audio input: Microphone (Realtek High Definition Audio)
18:58:49: Audio Encoding: AAC
18:58:49: bitrate: 192
18:58:49: Using graphics capture
18:58:49: Using custom x264 settings: "vbv-maxbitrate=1000"
18:58:49: The custom x264 command 'vbv-maxbitrate=1000' failed
18:58:49: Video Encoding: x264
18:58:49: fps: 30
18:58:49: width: 1920, height: 1080
18:58:49: preset: veryfast
18:58:49: CBR: no
18:58:49: CFR: no
18:58:49: max bitrate: 2500
18:58:49: buffer size: 5000
18:58:49: quality: 8
18:58:49: SharedTexCapture hooked
18:58:50: Total frames rendered: 43, number of frames that lagged: 1 (2.33%) (it's okay for some frames to lag)
18:58:50: =====Stream End: 2013-06-30, 18:58:50=================================================
19:00:28: =====Stream Start: 2013-06-30, 19:00:28===============================================
19:00:28: Multithreaded optimizations: On
19:00:28: Base resolution: 1920x1080
19:00:28: Output resolution: 1920x1080
19:00:28: ------------------------------------------
19:00:28: Loading up D3D10...
19:00:28: Playback device Default
19:00:28: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:00:28: Using 5.1 speaker setup
19:00:28: Using auxilary audio input: Microphone (Realtek High Definition Audio)
19:00:28: Audio Encoding: AAC
19:00:28: bitrate: 192
19:00:28: Using graphics capture
19:00:28: Using custom x264 settings: "vbv-maxbitrate=1000"
19:00:28: The custom x264 command 'vbv-maxbitrate=1000' failed
19:00:28: Video Encoding: x264
19:00:28: fps: 30
19:00:28: width: 1920, height: 1080
19:00:28: preset: veryfast
19:00:28: CBR: no
19:00:28: CFR: no
19:00:28: max bitrate: 2500
19:00:28: buffer size: 5000
19:00:28: quality: 8
19:00:28: SharedTexCapture hooked
19:00:30: Using RTMP service: Twitch / Justin.tv
19:00:30: Server selection: rtmp://live-dfw.justin.tv/app
19:00:32: SO_SNDBUF was at 8192
19:00:32: SO_SNDBUF is now 65536
19:54:27: Total frames rendered: 97177, number of frames that lagged: 2 (0.00%) (it's okay for some frames to lag)
19:54:27: RTMPPublisher::SocketLoop: Aborting due to bStopping
19:54:27: Number of times waited to send: 2, Waited for a total of 1218 bytes
19:54:27: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
19:54:27: =====Stream End: 2013-06-30, 19:54:27=================================================
19:54:27: =====Stream Start: 2013-06-30, 19:54:27===============================================
19:54:27: Multithreaded optimizations: On
19:54:27: Base resolution: 1920x1080
19:54:27: Output resolution: 1920x1080
19:54:27: ------------------------------------------
19:54:27: Loading up D3D10...
19:54:27: Playback device Default
19:54:27: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:54:27: Using 5.1 speaker setup
19:54:27: Using auxilary audio input: Microphone (Realtek High Definition Audio)
19:54:27: Audio Encoding: AAC
19:54:27: bitrate: 192
19:54:27: Using graphics capture
19:54:27: Using custom x264 settings: "vbv-maxbitrate=1000"
19:54:27: The custom x264 command 'vbv-maxbitrate=1000' failed
19:54:27: Video Encoding: x264
19:54:27: fps: 30
19:54:27: width: 1920, height: 1080
19:54:27: preset: veryfast
19:54:27: CBR: no
19:54:27: CFR: no
19:54:27: max bitrate: 5000
19:54:27: buffer size: 5000
19:54:27: quality: 8
19:54:28: SharedTexCapture hooked
19:54:30: Using RTMP service: Twitch / Justin.tv
19:54:30: Server selection: rtmp://live-dfw.justin.tv/app
19:54:31: SO_SNDBUF was at 8192
19:54:31: SO_SNDBUF is now 65536
19:58:40: Total frames rendered: 7584, number of frames that lagged: 8 (0.11%) (it's okay for some frames to lag)
19:58:40: RTMPPublisher::SocketLoop: Aborting due to bStopping
19:58:40: Number of times waited to send: 49, Waited for a total of 188742 bytes
19:58:40: Number of b-frames dropped: 109 (1.5%), Number of p-frames dropped: 153 (2.1%), Total 262 (3.5%)
19:58:40: =====Stream End: 2013-06-30, 19:58:40=================================================
19:59:07: =====Stream Start: 2013-06-30, 19:59:07===============================================
19:59:07: Multithreaded optimizations: On
19:59:07: Base resolution: 1920x1080
19:59:07: Output resolution: 1920x1080
19:59:07: ------------------------------------------
19:59:07: Loading up D3D10...
19:59:07: Playback device Default
19:59:07: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:59:07: Using 5.1 speaker setup
19:59:07: Using auxilary audio input: Microphone (Realtek High Definition Audio)
19:59:07: Audio Encoding: AAC
19:59:07: bitrate: 192
19:59:07: Using graphics capture
19:59:07: Using custom x264 settings: "vbv-maxbitrate=1000"
19:59:07: The custom x264 command 'vbv-maxbitrate=1000' failed
19:59:07: Video Encoding: x264
19:59:07: fps: 30
19:59:07: width: 1920, height: 1080
19:59:07: preset: veryfast
19:59:07: CBR: no
19:59:07: CFR: no
19:59:07: max bitrate: 8000
19:59:07: buffer size: 8000
19:59:07: quality: 8
19:59:07: SharedTexCapture hooked
19:59:09: Using RTMP service: Twitch / Justin.tv
19:59:09: Server selection: rtmp://live-dfw.justin.tv/app
19:59:11: SO_SNDBUF was at 8192
19:59:11: SO_SNDBUF is now 65536
20:15:03: Total frames rendered: 28676, number of frames that lagged: 1 (0.00%) (it's okay for some frames to lag)
20:15:03: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:15:03: Number of times waited to send: 0, Waited for a total of 0 bytes
20:15:03: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:15:03: =====Stream End: 2013-06-30, 20:15:03=================================================
20:15:04: =====Stream Start: 2013-06-30, 20:15:04===============================================
20:15:04: Multithreaded optimizations: On
20:15:04: Base resolution: 1920x1080
20:15:04: Output resolution: 1920x1080
20:15:04: ------------------------------------------
20:15:04: Loading up D3D10...
20:15:04: Playback device Default
20:15:04: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:15:04: Using 5.1 speaker setup
20:15:04: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:15:04: Audio Encoding: AAC
20:15:04: bitrate: 192
20:15:04: Using graphics capture
20:15:04: Using custom x264 settings: "vbv-maxbitrate=1000"
20:15:04: The custom x264 command 'vbv-maxbitrate=1000' failed
20:15:04: Video Encoding: x264
20:15:04: fps: 30
20:15:04: width: 1920, height: 1080
20:15:04: preset: veryfast
20:15:04: CBR: no
20:15:04: CFR: no
20:15:04: max bitrate: 15000
20:15:04: buffer size: 15000
20:15:04: quality: 8
20:15:04: SharedTexCapture hooked
20:15:06: Using RTMP service: Twitch / Justin.tv
20:15:06: Server selection: rtmp://live-dfw.justin.tv/app
20:15:07: SO_SNDBUF was at 8192
20:15:07: SO_SNDBUF is now 65536
20:18:07: Total frames rendered: 5516, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
20:18:07: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:18:07: Number of times waited to send: 0, Waited for a total of 0 bytes
20:18:07: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:18:08: =====Stream End: 2013-06-30, 20:18:08=================================================
20:18:08: =====Stream Start: 2013-06-30, 20:18:08===============================================
20:18:08: Multithreaded optimizations: On
20:18:08: Base resolution: 1920x1080
20:18:08: Output resolution: 1920x1080
20:18:08: ------------------------------------------
20:18:08: Loading up D3D10...
20:18:08: Playback device Default
20:18:08: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:18:08: Using 5.1 speaker setup
20:18:08: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:18:08: Audio Encoding: AAC
20:18:08: bitrate: 192
20:18:08: Using graphics capture
20:18:08: Using custom x264 settings: "vbv-maxbitrate=1000"
20:18:08: The custom x264 command 'vbv-maxbitrate=1000' failed
20:18:08: Video Encoding: x264
20:18:08: fps: 60
20:18:08: width: 1920, height: 1080
20:18:08: preset: veryfast
20:18:08: CBR: no
20:18:08: CFR: no
20:18:08: max bitrate: 5000
20:18:08: buffer size: 5000
20:18:08: quality: 8
20:18:08: SharedTexCapture hooked
20:18:09: Using RTMP service: Twitch / Justin.tv
20:18:09: Server selection: rtmp://live-dfw.justin.tv/app
20:18:11: SO_SNDBUF was at 8192
20:18:11: SO_SNDBUF is now 65536
20:19:16: Total frames rendered: 4106, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
20:19:16: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:19:16: Number of times waited to send: 0, Waited for a total of 0 bytes
20:19:16: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:19:16: =====Stream End: 2013-06-30, 20:19:16=================================================
20:19:17: =====Stream Start: 2013-06-30, 20:19:17===============================================
20:19:17: Multithreaded optimizations: On
20:19:17: Base resolution: 1920x1080
20:19:17: Output resolution: 1920x1080
20:19:17: ------------------------------------------
20:19:17: Loading up D3D10...
20:19:17: Playback device Default
20:19:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:19:17: Using 5.1 speaker setup
20:19:17: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:19:17: Audio Encoding: AAC
20:19:17: bitrate: 192
20:19:17: Using graphics capture
20:19:17: Using custom x264 settings: "vbv-maxbitrate=1000"
20:19:17: The custom x264 command 'vbv-maxbitrate=1000' failed
20:19:17: Video Encoding: x264
20:19:17: fps: 30
20:19:17: width: 1920, height: 1080
20:19:17: preset: veryfast
20:19:17: CBR: no
20:19:17: CFR: no
20:19:17: max bitrate: 5000
20:19:17: buffer size: 5000
20:19:17: quality: 8
20:19:17: SharedTexCapture hooked
20:19:19: Using RTMP service: Twitch / Justin.tv
20:19:19: Server selection: rtmp://live-dfw.justin.tv/app
20:19:21: SO_SNDBUF was at 8192
20:19:21: SO_SNDBUF is now 65536
20:20:13: Total frames rendered: 1680, number of frames that lagged: 1 (0.06%) (it's okay for some frames to lag)
20:20:13: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:20:13: Number of times waited to send: 0, Waited for a total of 0 bytes
20:20:13: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:20:13: =====Stream End: 2013-06-30, 20:20:13=================================================
20:20:13: =====Stream Start: 2013-06-30, 20:20:13===============================================
20:20:13: Multithreaded optimizations: On
20:20:13: Base resolution: 1920x1080
20:20:13: Output resolution: 1920x1080
20:20:13: ------------------------------------------
20:20:13: Loading up D3D10...
20:20:14: Playback device Default
20:20:14: ------------------------------------------
20:20:14: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:20:14: Using 5.1 speaker setup
20:20:14: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:20:14: Audio Encoding: AAC
20:20:14: bitrate: 192
20:20:14: Using graphics capture
20:20:14: Using custom x264 settings: "vbv-maxbitrate=1000"
20:20:14: The custom x264 command 'vbv-maxbitrate=1000' failed
20:20:14: Video Encoding: x264
20:20:14: fps: 30
20:20:14: width: 1920, height: 1080
20:20:14: preset: veryfast
20:20:14: CBR: no
20:20:14: CFR: no
20:20:14: max bitrate: 5000
20:20:14: buffer size: 5000
20:20:14: quality: 5
20:20:14: SharedTexCapture hooked
20:20:16: Using RTMP service: Twitch / Justin.tv
20:20:16: Server selection: rtmp://live-dfw.justin.tv/app
20:20:18: SO_SNDBUF was at 8192
20:20:18: SO_SNDBUF is now 65536
20:22:56: Total frames rendered: 4867, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
20:22:56: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:22:56: Number of times waited to send: 0, Waited for a total of 0 bytes
20:22:56: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:22:56: =====Stream End: 2013-06-30, 20:22:56=================================================
20:22:56: =====Stream Start: 2013-06-30, 20:22:56===============================================
20:22:56: Multithreaded optimizations: On
20:22:56: Base resolution: 1920x1080
20:22:56: Output resolution: 1920x1080
20:22:56: ------------------------------------------
20:22:56: Loading up D3D10...
20:22:56: Playback device Default
20:22:56: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:22:56: Using 5.1 speaker setup
20:22:56: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:22:56: Audio Encoding: AAC
20:22:56: bitrate: 192
20:22:56: Using graphics capture
20:22:56: Using custom x264 settings: "vbv-maxbitrate=1000"
20:22:56: The custom x264 command 'vbv-maxbitrate=1000' failed
20:22:56: Video Encoding: x264
20:22:56: fps: 30
20:22:56: width: 1920, height: 1080
20:22:56: preset: veryfast
20:22:56: CBR: no
20:22:56: CFR: no
20:22:56: max bitrate: 15000
20:22:56: buffer size: 15000
20:22:56: quality: 5
20:22:56: SharedTexCapture hooked
20:22:58: Using RTMP service: Twitch / Justin.tv
20:22:58: Server selection: rtmp://live-dfw.justin.tv/app
20:23:00: SO_SNDBUF was at 8192
20:23:00: SO_SNDBUF is now 65536
20:23:30: Total frames rendered: 1011, number of frames that lagged: 1 (0.10%) (it's okay for some frames to lag)
20:23:30: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:23:30: Number of times waited to send: 0, Waited for a total of 0 bytes
20:23:30: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:23:30: =====Stream End: 2013-06-30, 20:23:30=================================================
20:23:30: =====Stream Start: 2013-06-30, 20:23:30===============================================
20:23:30: Multithreaded optimizations: On
20:23:30: Base resolution: 1920x1080
20:23:30: Output resolution: 1920x1080
20:23:30: ------------------------------------------
20:23:30: Loading up D3D10...
20:23:30: Playback device Default
20:23:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:23:30: Using 5.1 speaker setup
20:23:30: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:23:30: Audio Encoding: AAC
20:23:30: bitrate: 192
20:23:30: Using graphics capture
20:23:30: Using custom x264 settings: "vbv-maxbitrate=8000"
20:23:30: The custom x264 command 'vbv-maxbitrate=8000' failed
20:23:30: Video Encoding: x264
20:23:30: fps: 30
20:23:30: width: 1920, height: 1080
20:23:30: preset: veryfast
20:23:30: CBR: no
20:23:30: CFR: no
20:23:30: max bitrate: 8000
20:23:30: buffer size: 8000
20:23:30: quality: 5
20:23:30: SharedTexCapture hooked
20:23:32: Using RTMP service: Twitch / Justin.tv
20:23:32: Server selection: rtmp://live-dfw.justin.tv/app
20:23:35: SO_SNDBUF was at 8192
20:23:35: SO_SNDBUF is now 65536
20:23:59: Total frames rendered: 854, number of frames that lagged: 1 (0.12%) (it's okay for some frames to lag)
20:23:59: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:23:59: Number of times waited to send: 0, Waited for a total of 0 bytes
20:23:59: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:23:59: =====Stream End: 2013-06-30, 20:23:59=================================================
20:23:59: =====Stream Start: 2013-06-30, 20:23:59===============================================
20:23:59: Multithreaded optimizations: On
20:23:59: Base resolution: 1920x1080
20:23:59: Output resolution: 1920x1080
20:23:59: ------------------------------------------
20:23:59: Loading up D3D10...
20:23:59: Playback device Default
20:23:59: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:23:59: Using 5.1 speaker setup
20:23:59: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:23:59: Audio Encoding: AAC
20:23:59: bitrate: 192
20:23:59: Using graphics capture
20:23:59: Using custom x264 settings: "vbv-maxbitrate=8000"
20:23:59: The custom x264 command 'vbv-maxbitrate=8000' failed
20:23:59: Video Encoding: x264
20:23:59: fps: 30
20:23:59: width: 1920, height: 1080
20:23:59: preset: veryfast
20:23:59: CBR: no
20:23:59: CFR: no
20:23:59: max bitrate: 8000
20:23:59: buffer size: 8000
20:23:59: quality: 5
20:23:59: SharedTexCapture hooked
20:24:01: Using RTMP service: Twitch / Justin.tv
20:24:01: Server selection: rtmp://live-dfw.justin.tv/app
20:24:03: SO_SNDBUF was at 8192
20:24:03: SO_SNDBUF is now 65536
20:24:18: Total frames rendered: 578, number of frames that lagged: 1 (0.17%) (it's okay for some frames to lag)
20:24:18: RTMPPublisher::SocketLoop: Aborting due to bStopping
20:24:18: Number of times waited to send: 0, Waited for a total of 0 bytes
20:24:18: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:24:18: =====Stream End: 2013-06-30, 20:24:18=================================================
20:24:28: =====Stream Start: 2013-06-30, 20:24:28===============================================
20:24:28: Multithreaded optimizations: On
20:24:28: Base resolution: 1920x1080
20:24:28: Output resolution: 1920x1080
20:24:28: ------------------------------------------
20:24:28: Loading up D3D10...
20:24:28: Playback device Default
20:24:28: Using desktop audio input: Speakers (Realtek High Definition Audio)
20:24:28: Using 5.1 speaker setup
20:24:28: Using auxilary audio input: Microphone (Realtek High Definition Audio)
20:24:29: ------------------------------------------
20:24:29: Audio Encoding: AAC
20:24:29: bitrate: 192
20:24:29: Using graphics capture
20:24:29: Using custom x264 settings: "vbv-maxbitrate=8000"
20:24:29: The custom x264 command 'vbv-maxbitrate=8000' failed
20:24:29: Video Encoding: x264
20:24:29: fps: 60
20:24:29: width: 1920, height: 1080
20:24:29: preset: veryfast
20:24:29: CBR: no
20:24:29: CFR: no
20:24:29: max bitrate: 8000
20:24:29: buffer size: 8000
20:24:29: quality: 5
20:24:29: SharedTexCapture hooked
20:24:30: Using RTMP service: Twitch / Justin.tv
20:24:30: Server selection: rtmp://live-dfw.justin.tv/app
20:24:32: SO_SNDBUF was at 8192
20:24:32: SO_SNDBUF is now 65536
21:01:02: Total frames rendered: 131591, number of frames that lagged: 7 (0.01%) (it's okay for some frames to lag)
21:01:02: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:01:02: Number of times waited to send: 0, Waited for a total of 0 bytes
21:01:02: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:01:02: =====Stream End: 2013-06-30, 21:01:02=================================================
21:01:05:
21:01:05: Profiler results:
21:01:05:
21:01:05: ==============================================================
21:01:05: frame - [100%] [avg time: 2.737 ms] [avg calls per frame: 1] [children: 80.5%] [unaccounted: 19.5%]
21:01:05: | scene->Preprocess - [0%] [avg time: 0 ms] [avg calls per frame: 1]
21:01:05: | video encoding and uploading - [80.5%] [avg time: 2.203 ms] [avg calls per frame: 1] [children: 79.6%] [unaccounted: 0.913%]
21:01:05: | | CopyResource - [0.585%] [avg time: 0.016 ms] [avg calls per frame: 0]
21:01:05: | | conversion to 4:2:0 - [0.658%] [avg time: 0.018 ms] [avg calls per frame: 0]
21:01:05: | | call to encoder - [77.6%] [avg time: 2.124 ms] [avg calls per frame: 0]
21:01:05: | | sending stuff out - [0.731%] [avg time: 0.02 ms] [avg calls per frame: 0]
