Draknishar
I seem to be having issues with streaming league of legends, I feel I should be able to stream and still have normal 60fps in-game no problem but this does not seem to be the case. Any help would be appreciated.
21:02:59: Open Broadcaster Software v0.542b - 64bit ( ^ω^)
21:02:59: -------------------------------
21:02:59: CPU Name: AMD Phenom(tm) II X6 1090T Processor
21:02:59: CPU Speed: 3214MHz
21:02:59: Physical Memory: 12285MB Total, 8334MB Free
21:02:59: stepping id: 0, model 10, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 6, total cores 6
21:02:59: monitor 1: pos={0, 0}, size={1920, 1200}
21:02:59: monitor 2: pos={1920, 0}, size={1920, 1200}
21:02:59: Windows Version: 6.1 Build 7600
21:02:59: Aero is Disabled
21:02:59: OBS Modules:
21:02:59: Base Address Module
21:02:59: 000000003F210000 OBS.exe
21:02:59: 00000000F2C90000 OBSApi.dll
21:02:59: 00000000F6610000 DShowPlugin.dll
21:02:59: 00000000F65E0000 GraphicsCapture.dll
21:02:59: 00000000F70D0000 NoiseGate.dll
21:02:59: 00000000FAF60000 PSVPlugin.dll
21:02:59: ------------------------------------------
21:02:59: Adapter 1
21:02:59: Video Adapter: NVIDIA GeForce GTX 460
21:02:59: Video Adapter Dedicated Video Memory: 774307840
21:02:59: Video Adapter Shared System Memory: 3489497088
21:02:59: =====Stream Start: 2013-07-25, 21:02:59===============================================
21:02:59: Multithreaded optimizations: On
21:02:59: Base resolution: 1920x1200
21:02:59: Output resolution: 1920x1200
21:02:59: Loading up D3D10...
21:02:59: Playback device Default
21:02:59: Using desktop audio input: Headphones (High Definition Audio Device)
21:02:59: Using auxilary audio input: Microphone (VF0700 Live! Cam Chat HD)
21:02:59: Audio Encoding: MP3
21:02:59: bitrate: 96
21:02:59: device: Live! Cam Chat HD (VF0700),
21:02:59: device id \\?\usb#vid_041e&pid_4088&mi_00#7&370fa0c&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:02:59: chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000, fourCC: 'YUY2'
21:02:59: audio device: Disable,
21:02:59: audio device id Disabled,
21:02:59:
21:02:59: Using directshow input
21:02:59: Using graphics capture
21:02:59: Using Monitor Capture
21:02:59: Video Encoding: x264
21:02:59: fps: 24
21:02:59: width: 1920, height: 1200
21:02:59: preset: veryfast
21:02:59: CBR: yes
21:02:59: CFR: yes
21:02:59: max bitrate: 5000
21:02:59: SharedTexCapture hooked
21:03:01: Using RTMP service: Twitch / Justin.tv
21:03:01: Server selection: rtmp://live-lhr.justin.tv/app
21:03:03: SO_SNDBUF was at 8192
21:03:03: SO_SNDBUF is now 65536
21:10:45: Exit signal received, terminating capture
21:11:07: Total frames rendered: 11710, number of frames that lagged: 5 (0.04%) (it's okay for some frames to lag)
21:11:07: Total duplicated frames: 6 (0.05%)
21:11:07: RTMPPublisher::SocketLoop: Aborting due to loop exit
21:11:07: librtmp error: WriteN, RTMP send error 10035 (84 bytes)
21:11:07: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
21:11:07: Number of times waited to send: 0, Waited for a total of 0 bytes
21:11:07: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:11:07: =====Stream End: 2013-07-25, 21:11:07=================================================
21:11:09: =====Stream Start: 2013-07-25, 21:11:09===============================================
21:11:09: Multithreaded optimizations: On
21:11:09: Base resolution: 1920x1200
21:11:09: Output resolution: 960x600
21:11:09: ------------------------------------------
21:11:09: Loading up D3D10...
21:11:09: Playback device Default
21:11:09: Using desktop audio input: Headphones (High Definition Audio Device)
21:11:09: Using auxilary audio input: Microphone (VF0700 Live! Cam Chat HD)
21:11:09: Audio Encoding: MP3
21:11:09: bitrate: 96
21:11:09: device: Live! Cam Chat HD (VF0700),
21:11:09: device id \\?\usb#vid_041e&pid_4088&mi_00#7&370fa0c&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
21:11:09: chosen type: YUY2, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000, fourCC: 'YUY2'
21:11:09: audio device: Disable,
21:11:09: audio device id Disabled,
21:11:09:
21:11:09: Using directshow input
21:11:09: Using graphics capture
21:11:09: Using Monitor Capture
21:11:09: Video Encoding: x264
21:11:09: fps: 24
21:11:09: width: 960, height: 600
21:11:09: preset: veryfast
21:11:09: CBR: yes
21:11:09: CFR: yes
21:11:09: max bitrate: 5000
21:11:11: Using RTMP service: Twitch / Justin.tv
21:11:11: Server selection: rtmp://live-lhr.justin.tv/app
21:11:13: SO_SNDBUF was at 8192
21:11:13: SO_SNDBUF is now 65536
21:12:08: SharedTexCapture hooked
21:18:23: Total frames rendered: 10422, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
21:18:23: Total duplicated frames: 0 (0.00%)
21:18:24: RTMPPublisher::SocketLoop: Aborting due to bStopping
21:18:24: Number of times waited to send: 0, Waited for a total of 0 bytes
21:18:24: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
21:18:24: =====Stream End: 2013-07-25, 21:18:24=================================================
21:18:27:
21:18:27: Profiler results:
21:18:27:
21:18:27: ==============================================================
21:18:27: frame - [100%] [avg time: 18.322 ms (cpu time: avg 10.748 ms, total 237886 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0327%]
21:18:27: | frame preprocessing and rendering - [76.5%] [avg time: 14.009 ms (cpu time: avg 6.654 ms, total 147281 ms)] [avg calls per frame: 1] [children: 71.7%] [unaccounted: 4.73%]
21:18:27: | | scene->Preprocess - [71.7%] [avg time: 13.143 ms (cpu time: avg 5.87 ms, total 129918 ms)] [avg calls per frame: 1]
21:18:27: | video encoding and uploading - [23.5%] [avg time: 4.307 ms (cpu time: avg 4.089 ms, total 90511.8 ms)] [avg calls per frame: 1] [children: 23.3%] [unaccounted: 0.24%]
21:18:27: | | flush - [0.649%] [avg time: 0.119 ms (cpu time: avg 0.098 ms, total 2184.01 ms)] [avg calls per frame: 1]
21:18:27: | | CopyResource - [0.131%] [avg time: 0.024 ms (cpu time: avg 0.021 ms, total 468 ms)] [avg calls per frame: 0]
21:18:27: | | conversion to 4:2:0 - [0.409%] [avg time: 0.075 ms (cpu time: avg 0.026 ms, total 577.206 ms)] [avg calls per frame: 0]
21:18:27: | | call to encoder - [21.7%] [avg time: 3.969 ms (cpu time: avg 3.861 ms, total 85457.4 ms)] [avg calls per frame: 0]
21:18:27: | | sending stuff out - [0.415%] [avg time: 0.076 ms (cpu time: avg 0.065 ms, total 1450.81 ms)] [avg calls per frame: 0]
21:18:27: | Convert444Threads - [909%] [avg time: 166.531 ms (cpu time: avg 5.93 ms, total 131244 ms)] [avg calls per frame: 3]
21:18:27:
