Logitech G Hub Integration [Deleted]
Status
Not open for further replies.
AdrienCasier
AdrienCasier submitted a new resource:
Logitech G Hub Integration - Enable Logitech G Hub OBS Integration by exposing actions from OBS to G Hub websocket server
OBS Logitech G Hub Integration​
This is a plugin for OBS Studio exposing actions to G HUB, allowing users to take control of their OBS setup through Logitech G peripherals.
I used the source code from ghub-obs-plugin (official plugin from Logitech), updated their dependencies and encapsulated the project in the official OBS plugin template.
Feel free to contribute to this project.
eZuercher
>>>>>"obs-lghub-integration-1.0.0-macos-x86_64l.pkg<<<<<<<`
Since installed, OBS crashes. neither restart nor re/deinstallation this Plugin helped.
Wondering there are uncountable workarounds on different platforms but no comments or discussion on obs platform..?
hmm, plugin folder is empty...
  • crashlog -- %22obs-lghub-integration-1.0.0-macos-x86_64l%22.pdf
Jaibyrd
I have this same issue! Now I can't get OBS to work anymore no matter what I do! User beware!
AdrienCasier
I'm sorry to see that I've harmed your OBS installation. I cannot test on MacOS.
Thanks to eZuercher I now have a crash report to analyze.
You can remove the plugin manually in the plugin folder (
Something like that: /Users/USER/Library/Application Support/obs-studio/*/obs-lghub-
integration.plugin/Contents/MacOS/obs-lghub-integration
Alexi Space
is it really MIT license as long as you used the logitech official plugin code? The official repository doesn't have license.
Status
