Bug Report LGHD Stream Engine Resolution Changing
JoeKnowsGames
Using my Avermedia Live Gamer HD and the LGHD Stream Engine software, I set the resolution to 1920x1080, 30 FPS. (I've also tried this with 1280x720).
When I go into OBS and either Preview Stream or Start Streaming, it automatically changes the resolution in the Stream Engine to 720x480 - without fail. I have to stop streaming/previewing, and when I change it back to try again, it still shifts the resolution.
This results in both a skewed stream and a low resolution when I try to play the game. Is there any way to prevent the resolution shift?
Lain
Lain
That does seem unusual, that definitely shouldn't happen. Mind if I see a log file real quick? Are the resolutions you're requesting listed in the drop-down?
JoeKnowsGames
Thanks for the reply.
*Facepalm*
I figured out the issue. The console was automatically lowering its resolution because it wasn't passing through HDCP with the Live Gamer HD. PS4 patch 1.70 was kinda useless after all.
Guess I'll go back to using my workaround :(.
