Latency Issues during screen recording Valorant
Reeju
I have been experiencing latency issues during screen recording Valorant gameplays for VOD reviews I am unable to identify the issue if you could help it would be appreciated.
  • 2023-08-24 12-31-24.txt
qhobbes
1. The Hardware-accelerated GPU scheduling ("HAGS") feature is currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via these instructions.
2. Change the refresh rate on your screen from 144 Hz to 120 Hz and cap your games at 120 FPS.
3. Recording at a tremendously high framerate will not give you higher quality recordings. Usually quite the opposite. Most computers cannot handle encoding at high framerates. Framerates other than 30fps or 60fps may lead to playback issues like stuttering or screen tearing. Stick to either of these for better compatibility with video players. You can change your OBS frame rate in Settings -> Video.
4. Your log contains no recording session. Results of this log analysis are limited. Please post a link to a clean log file.
1) Restart OBS.
2) Start your recording for at least 30 seconds. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc.
3) Stop your recording.
4) Select Help > Log Files > Upload Current Log File. Send that link to the analyzer. If still having issues, send that link here.
