Issues with OBS
Skoule
Hello, I recently built a streaming PC with the following components:
  • Asus Prime B550-Plus, motherboard
  • AMD Ryzen 7 5800X CPU
  • be quiet! Dark Rock 5, CPU cooler
  • Patriot 32 GB DDR4-3200 (2×16 GB) Dual Kit, RAM
  • Gainward GeForce RTX 5060 Ghost 8GB OC, GPU
  • Crucial P310 1 TB SSD
  • be quiet! System Power 11 650W ATX 3.1 power supply
  • Elgato 4K Pro MK 2 capture card
The problem is: Whenever I open OBS on the streaming PC and try to use the cloned image from the gaming PC via the Elgato capture card as a source, OBS starts lagging heavily and becomes unusable.
Does anyone have a solution for this?
  • 2025-07-11 20-08-31.txt
Please attach a full log file, not edited/deleted some lines. You can also upload the current or previous log file using the built in feature you'll find inside the Help menu.
