JohnPreston[GC]
Recently, Illustrator CC was updated to include using your NVIDIA GPU for a performance boost. However, any time I use the GPU mode in Illustrator while streaming (or recording), the screen stops updating and the the image becomes static (as in not moving), and the only action shown is the cursor moving across the screen. The second I turn off GPU mode, the stream updates everything to its current position, and captures fine, so long as I do not go into GPU mode. The process repeats as I switch between the two modes
I assume that there is some override issues between OBS and Illustrator when using the GPU. Here are the logs if it helps at all: http://pastebin.com/xkF6qVtE
Edit: I forgot to mention something fairly important. This only happens in Window Capture. If I use Monitor Capture, it works, but with lag.
