iOS Camera audio missing with 29.0.0 update (macOS)
kvanderw
I updated to OBS 29.0.0 on M1 MacBook Pro.
I believe I used the ARM version. I did it twice to make sure.
I Updated the iOS Camera since that was totally broke from 28.x
Camera works!
Audio.... not so much.
The Audio Mixer shows a meter for the iOS Camera but there seems to be a shadow on the meter. It has NO movement of any kind.
It looks almost like a placeholder.
I have attached photos of both the Audio Mixer as well as the "Settings" for the Audio Mixer as well.
I don't believe (Doesn't mean I didn't) that I changed anything else with the update.....
So, confused and can't find anyone else running into the same problem.
I have rebooted both iOS and MacOS more than once since this problem started.
Any ideas are greatly appreciated.
  • OBS Audio Problems.pdf
jmehl
Camera works!
Did you ever get this resolved ? I been using OBS for years and did a fresh install and have the same issue all of a sudden. Frustrating hey.
