INSTANT OBS CRASHING- Please Help Details Inside
yoggerzz
Unhandled exception: e06d7363
Date/Time: 2022-02-15, 16:46:48
Fault address: 7FFE60B34F69 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.0 (64-bit)
Windows version: 10.0 build 19044 (release: 2009; revision: 1526; 64-bit)
CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
here is part of the crash log. did update today and bam. can't run OBS. instant crashes. reinstalled, restarted computer. any help much appreciated.
  • Crash 2022-02-15 16-46-49.txt
cyclemat
update your GPU drivers !
check you windows instalation open a CMD window as admin type in
1st "DISM.exe /Online /Cleanup-image /Restorehealth"
wait to finish then
2nd "sfc /scannow"
yoggerzz
wait to finish then
2nd "sfc /scannow"
thank you. got error: 87 when i ran the first command.
yoggerzz
wait to finish then
2nd "sfc /scannow"
it says the online/cleanup-image/restorehealth option is unknown. after running the second command it said that corrupted files were repaired but still have the exact same issue and it wont launch OBS
yoggerzz
i am completely up to date on all OS things and drivers. this is making me go crazy. LITERALLY used OBS right before the update to record a video. literally. updated and boom. everything is messed up. however now streamlabs OBS is working. i really dont want to use them.
cyclemat
did you have start the cmd with admin privilegs ?
is in the window name running as Admin?
try this commands
  • DISM /Online /Cleanup-image /Scanhealth
  • DISM /Online /Cleanup-image /Restorehealth
try also the aio runtime installer
yoggerzz
absolutely nothing is working.. i just did a clean reinstall of GPU drivers, the program, i did all those commands and it ran the scans and said no corruption or anything. and still obs just will not launch.
