Input Overlay
Input Overlay v5.0.5
Shiyo
Hello.I installed it successfully.After i creat a new input overlay source in OBS and choose .png and .json files ,it presented correctly .But it has no response for neither my keyboard nor mouse .What' wrong?
Shiyo
Maybe i found out the reason.I choose the input controll in settings :)
Kyogre
I don't know what you mean but you can create two browser sources that use two different presets I guess.
My bad. Tried my old OBS v27 one more time and after that know I understood that there never was a source, that could show letters of two keyboard languages simultaneously.
arizamuuru
Hey, I used the installer but despite that I don't have the ability to capture the input overlay source. Anyone know what's wrong?
retrounderbelly
Hey guys. I started a genesis controller template. Just learning now, but if someone understands the process better, feel free to use this images. I will post any progress.
Yiung
Same problem here, I cannot locate input-overlay in the tools or sources. Was there a change with how OBS parses plugins from the original posting of the tutorial video? OBS was on version 27 in the tutorial video, and the most current version is 30.0.2
Yiung
Whoops, found out to problem. Just have two explorers open, and have one explorer on obs-studio proper and the other on the downloaded content's obs-studio. have all files and folders from the downloaded/installed obs-studio, and move them into the obs-studio proper. Solve the entire issue.
Repacharge
Hello, I am trying to customize my input overlay, and when I go to your io-cct github, I can modify the layout to be exactly how I want it, but I can only extract the .json, I still don't understand how to modify it to a .ini file, and how to get the .png file. Can you not extract it to a .png from that site?
BrenFu
Here is my overlay for the Sega Genesis / Mega Drive 3 button controller.
It shows both d-pad and left analog stick movements.
Button mappings were tested with an Xbox/Xinput controller.
  • Genesis_3_button_inputoverlay.zip
ZennanSR
will there ever be any type of snapping added to the io-cct tool? making a layout with it is extremely annoying because it's hard to align anything correctly without snapping. having any type of snapping feature added would save a lot of time and energy on making layouts.
adelinadragonborn
Greetings! I'm trying to figure out how to make Xbox Elite controller with 4 extra paddles to display paddles keystrokes in OBS with Input Overlay plugin, but unfortunately I couldn't find any info regarding keycodes of 4 new paddles (if there's any), and io-cct is unable to record keystrokes.
I have steam extended feature support driver installed, and steam interface by itself is working perfectly fine with new paddles (which are unbinded in xbox accessories by the way).
Is there any way to get new paddles working with Input Overlay anyhow?
Thanks!
demk
Hello!
is anyone else able to use input overlay when playing GTA5 ?
I tried do search anything but couldn't found a clue.
obs64.exe
Steam.exe
GTA5.exe
RockstarLauncher.exe
all are executed as administrator and when i'm in GTA 5 noone of the inputs are recognized by the input overlay, but in any other game ( for example gta san andreas ) it works perfecly. Even desktop, any other window it works as expected.
Is there anything more I need to execute as adm to be able to see the overla
univrsal
Thanks!
I don't know if browsers detect the paddles, so I'm not sure if I can add support for them to the editor. You should however be able to set the keycodes manually. Just untick "record keycode" and enter the number:
Here's the list of codes:
Specifically the paddles:
SDL_CONTROLLER_BUTTON_PADDLE116
SDL_CONTROLLER_BUTTON_PADDLE217
SDL_CONTROLLER_BUTTON_PADDLE318
SDL_CONTROLLER_BUTTON_PADDLE419
Not sure which one is the correct one, so you'll have to test that.
Hello!
obs64.exe
Steam.exe
GTA5.exe
It might just be that the anti cheat prevents the plugin from working. I don't think there's much that can be done in that case.
