Bug Report incompatible hook module
Status
Not open for further replies.
matticinyoattic
so it's my first time trying to stream, and ofcourse I am a little confused... I create my scene>create my source, selecting game capture and it brings up an error saying; "incompatible hook modules were detected in the OBS process. Please make sure OBS is added to the ignore list of capture programs such as DXTory, FRAPS, etc...and the stuff about changing the ignore list...but I'm not using an outside source for video capture, I'm using the one OBS provides. I'm not sure why OBS would ignore itself, thus I am confused as to how this is occuring.
Lain
Lain
If you use DXTory you need to add the OBS exe path (for example C:\Program Files (32bit)\OBS\OBS.exe) to the DXTory ignore list, then restart all the apps.
Imortist
Have the same problem here. Not using ANY overlay programs (MSI Afterburner doesn't count cuz It worked perfectly on previus patch). But today I can't start streaming cuz of this error.
KOKOStern
Just upgraded to 0.541b.
Never had any issues before.
Getting this one now, can't preview or stream at all.
Not using any program other than OBS. Opened a new scene with nothing in it - still can't record.
14:30:45: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
14:30:45: -------------------------------
14:30:45: CPU Name: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
14:30:45: CPU Speed: 2664MHz
14:30:45: Physical Memory: 4095MB Total, 3074MB Free
14:30:45: stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
14:30:45: monitor 1: pos={-1920, 0}, size={1920, 1080}
14:30:45: monitor 2: pos={0, 0}, size={1920, 1080}
14:30:45: Windows Version: 6.1 Build 7600
14:30:45: Aero is Disabled
14:30:45: OBS Modules:
14:30:45: Base Address Module
14:30:45: 00370000 OBS.exe
14:30:45: 6AD10000 OBSApi.dll
14:30:45: 71E60000 DShowPlugin.dll
14:30:45: 6FB30000 GraphicsCapture.dll
14:30:45: 6FA70000 NoiseGate.dll
14:30:45: 6F900000 PSVPlugin.dll
14:30:45: ------------------------------------------
14:30:45: Adapter 1
14:30:45: Video Adapter: NVIDIA GeForce GTX 660 Ti
14:30:45: Video Adapter Dedicated Video Memory: 2091319296
14:30:45: Video Adapter Shared System Memory: 2147479552
14:31:00: Incompatible modules detected.
14:38:04: Incompatible modules detected.
14:38:24: Incompatible modules detected.
14:43:01: Incompatible modules detected.
14:44:17: Incompatible modules detected.
dodgepong
Administrator
Community Helper
The new updated added incompatibility checks for ASUS OSD and EVGA Precision OSD. Make sure those programs are disabled, or set to ignore OBS.
linflas
also having a problem with this, it is MSI afterburner, if I shut MSI down, it works.. I cannot find a setting to ignore OBS in MSI, please help
GPU Tweak from asus which is basically the exact same thing works just fine with OBS, something got broke with this beta in regards to MSI afterburner
KOKOStern
For me it was MSI Afterburner. Solved it by closing the program. No idea how to have both running at the same time.
This makes no sense...
kynes11
I'm sry why would you implement this Check? I'm just curios never had any problems till this update. This really sucks I need afterburner open.
Lain
Lain
I made a temp build that fixes this issue for MSI afterburner users at (link removed) -- this will be either resolved or something that can be disabled in future updates
pronoobgr
I got the same problem but i fix it by doin this! I've got 64bit and i just went here: C:\Program Files (x86)\OBS\64bit
And i opened "Obs.exe". If you are using 32bit try to go here: C:\Program Files (x86)\OBS and open that "Obs.exe".
dodgepong
Administrator
Community Helper
The latest version of OBS should let you ignore this message, so you shouldn't need this special build. It's very out of date, anyway.
theskwerl
Is there any way to disable the error message entirely?
When I have a game open and use my hotkey to start streaming, it won't start streaming until I alt-tab out of the game to go to OBS and click Ignore which kind of defeats the purpose of having a hotkey to start it.
I have MSI Afterburner (with the OSD disabled, though it still seems to interfere with OBS) running to control the fan speed on my video card, as it's prone to overheat while gaming without it so closing out of it isn't really an option for me.
If there isn't any way to disable the error message, an option in the next build would be nice.
Lain
Lain
I thought that the option to disable it was available.
And yea, the MSI Afterburner utility is really useful, sometimes vital. For my previous video card, it was the only way to regulate the fan control properly to make it be quiet, so I know that feeling.
R1CH
Try nvidia inspector for NV cards, it can do the same without hooking or being open all the time.
Omiley
I had the same issue with MSI Afterburner. I easily fixed this by just using the 64bit version of OBS
Status
