Tetrahedrus
Hi all. I use OBS v0.625b on Windows Vista SP2 32-bit.
When you add a text source to the scene, you can edit it and save the changes just fine if the text is on the screen the entire time. However, I've noticed that if I were to untick the box for the text source, edit it, save it, and then tick the box again to make it reappear, the text won't show up. If you hit "edit scene," then the red resizing box is just four little squares that you can't move. You can hit CTRL+R to reset the text source's size, and it will reappear, so this is not a major thing, but it is an annoyance nonetheless.
Just to be even clearer, here's a GIF of my issue (beginning is after the short black screen):
I don't believe this is necessary, but here is my log in case it's useful: https://gist.github.com/anonymous/c1ee58cc11d7698b5b4d
