Bug Report IDs of audio and video are swapped in the final file using QSV
etadex
So today I again encountered a problem with importing a video recorded with OBS to Sony Vegas 13.It says file codec unsupported or corrupt file, so I loaded up Handbrake and encoded some small preview using the same Intel QSV encoding method.
Mediainfo of an OBS captured file:
General
Complete name : E:\Capture\1 (03).avi
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.91 GiB
Duration : 22mn 51s
Overall bit rate mode : Variable
Overall bit rate : 18.2 Mbps
Encoded date : UTC 2015-05-28 20:06:40
Tagged date : UTC 2015-05-28 20:06:40
Writing application : Open Broadcaster Software v0.651b
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=High@3.1
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 22mn 51s
Source duration : 22mn 51s
Bit rate mode : Variable
Bit rate : 17.9 Mbps
Maximum bit rate : 27.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 60.000 fps
Minimum frame rate : 58.824 fps
Maximum frame rate : 62.500 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.144
Stream size : 2.85 GiB (98%)
Source stream size : 2.85 GiB (98%)
Color primaries : BT.709
Transfer characteristics : sYCC
Matrix coefficients : BT.709
Color range : Full
mdhd_Duration : 1371716
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 6B
Duration : 22mn 51s
Bit rate mode : Constant
Bit rate : 320 Kbps
Channel(s) : channel0
Channel(s)_Original : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 52.3 MiB (2%)
Source stream size : 52.3 MiB (2%)
Writing library : LAME3.99.5
Mediainfo of a short preview:
General
Complete name : C:\Users\Антон\AppData\Local\Temp\tmp7656.mkv
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 88.1 MiB
Duration : 2mn 0s
Overall bit rate : 6 157 Kbps
Writing application : HandBrake 0.10.1 2015030800
Video
Format : AVC
Format settings, GOP : M=4, N=32
Codec ID : avc1
Duration : 2mn 0s
Bit rate : 5 985 Kbps
Minimum frame rate : 29.412 fps
Maximum frame rate : 500.000 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.048
Stream size : 85.6 MiB (97%)
Transfer characteristics : BT.709
Color range : Limited
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1mn 59s
Bit rate : 160 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Stream size : 2.29 MiB (3%)
Title : Stereo
So, as you all can see, audio in preview has an ID2 and video is ID1, but in mp4 captured file they are ID1 and ID2 respectively.Keeping in mind this is AVC used with "as close as I could get" settings in Handbrake to mimic OBS encoder profile, I can assume Vegas doesn't want to eat that mp4 because of tracks standing on the wrong IDs.
Or is it container that is messing up the import?
If so - pls add the option to choose MKV as a container, because the possibility of having to recode all of my 3gb+ gameplay videos in Handbrake prior to montage is somewhat grim and unwanted)
Sincerely, Anton.
p.s. oh, I forgot to mention that the preview one imports in Sony Vegas just fine, audio and video are in place and synced.
etadex
Are you sure it's not having problems because you renamed the MP4 to AVI?
Yes, renaming was just some jump of hope on my side.It doesnt import either is has .mp4 format nor .avi.Tested on various captured videos in that folder.All of them are .mp4. Didn't test with .flv yet, though.
Sorry, didn't want to confuse you)
