i9 12900k, RTX 3090ti, and video at 60 fps still blurry. I'm going crazy.
IdDaVinci
Hi, i would ask if someone could suggest me the right settings to get full quality video recordings at 2560:1080. I have an i9 12900k and a Nvidia RTX 3090ti.
I tried from many many many tutorials everywhere, but my videos are still blurry and laggy. Best settings i found is with CBR at 32000kps Nvidia Nvenc h264, 20560:1080 60fps no downscaled. But the video when finished, is still blurry and sometimes it lags. In the stats i saw i lose framerate sometimes.
I ask this because i can't get how, with a really good setup like this, my videos are bad!!!
Please help me i'm going crazy.
qhobbes
You should only use CBR for recording if you have disk space or write speed issues.
Tools > Auto-Config Wizard > Optimize just for recording > Complete the wizard and do not make any changes when done. Close and restart OBS and try a recording.
If still having issues, upload a log of a recording (see link below) and follow the steps in the Analyzer (link in sig).
If still having issues after that
IdDaVinci
Okay, i tried with the wizard-config but the downscaling makes the video too pixelated.
I post the log here with the last record (auto-wizard settings except for the screen resolution 3400x1440,even in the output).
ps. I've recently upgraded my setup adding a new 3TB motherboard SSD, so the space is not a problem. It could be even 1GB every minute.
  • 2025-01-06 08-21-48.txt
rockbottom
Never downscale when quality is important.
08:21:48.022: Game DVR: On > Off
08:21:48.023: McAfee: enabled (AV)
08:21:48.023: Microsoft Defender Antivirus: disabled (AV)
08:21:48.023: McAfee: enabled (FW)
Disable HAGS & run your monitor @ 120HZ when recording.
08:21:48.224: HAGS Status: Enabled (Default: No, Driver status: Supported)
08:21:48.225: Driver Version: 32.0.15.6094
08:21:48.225: output 0:
08:21:48.225: name=U34G2G4R3
08:21:48.225: pos={0, 0}
08:21:48.225: size={3440, 1440}
08:21:48.225: attached=true
08:21:48.225: refresh=144 > 120
Fix your Scene. Only (1) Display, Game or Window capture per to avoid interference.
08:21:49.106: - scene 'Scena':
08:21:49.107: - source: 'Cattura gioco' (game_capture)
08:21:49.107: - source: 'Minecraft' (game_capture)
Lower the CQ Level to the 15-18 range. 2 Second Keyframe Interval, Zero B Frames & disable Visual Tuning. Test
08:28:12.712: codec: H264
08:28:12.712: rate_control: CQP
08:28:12.712: bitrate: 0
08:28:12.712: cqp: 23 > 15-18
08:28:12.712: keyint: 250 > 2 Seconds
08:28:12.712: preset: p5
08:28:12.712: tuning: hq
08:28:12.712: multipass: qres
08:28:12.712: profile: high
08:28:12.712: width: 3440
08:28:12.712: height: 1440
08:28:12.712: b-frames: 2 > 0
08:28:12.712: lookahead: false
08:28:12.712: psycho_aq: true > false
08:28:12.712:
08:28:12.767: [CoreAudio AAC: 'simple_aac_recording0']: settings:
08:28:12.767: mode: AAC
08:28:12.767: bitrate: 192
08:28:12.767: sample rate: 48000
08:28:12.767: cbr: on
08:28:12.767: output buffer: 1536
