Bug Report I keep crashing when i stream any suggestions?
StubbornRadish
12:38:04: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
12:38:04: -------------------------------
12:38:04: CPU Name: AMD E1-1200 APU with Radeon(tm) HD Graphics
12:38:04: CPU Speed: 1397MHz
12:38:04: Physical Memory: 3678MB Total, 1521MB Free
12:38:04: stepping id: 0, model 2, family 15, type 0, extmodel 8, extfamily 2, HTT 1, logical cores 2, total cores 2
12:38:04: monitor 1: pos={0, 0}, size={1366, 768}
12:38:04: monitor 2: pos={1366, 0}, size={1024, 768}
12:38:04: Windows Version: 6.2 Build 9200
12:38:04: Aero is Enabled
12:38:04: OBS Modules:
12:38:04: Base Address Module
12:38:04: 009B0000 OBS.exe
12:38:04: 61440000 OBSApi.dll
12:38:04: 61200000 DShowPlugin.dll
12:38:04: 62E60000 GraphicsCapture.dll
12:38:04: 62800000 NoiseGate.dll
12:38:04: 611E0000 PSVPlugin.dll
12:38:04: ------------------------------------------
12:38:04: Adapter 1
12:38:04: Video Adapter: AMD Radeon HD 7310
12:38:04: Video Adapter Dedicated Video Memory: 394383360
12:38:04: Video Adapter Shared System Memory: 1660028928
12:38:04: =====Stream Start: 2013-07-22, 12:38:04===============================================
12:38:04: Multithreaded optimizations: On
12:38:04: Base resolution: 1280x800
12:38:04: Output resolution: 728x456
12:38:04: Loading up D3D10...
12:38:05: Playback device {0.0.0.00000000}.{40003204-9eab-4696-a668-f6b76435d976}
12:38:05: ------------------------------------------
12:38:05: Using desktop audio input: Speakers (Logitech Wireless Headset)
12:38:05: Using auxilary audio input: Microphone (Logitech Wireless Headset)
12:38:05: Audio Encoding: AAC
12:38:05: bitrate: 128
12:38:06: ------------------------------------------
12:38:06: device: TOSHIBA Web Camera - HD,
12:38:06: device id \\?\usb#vid_10f1&pid_1a43&mi_00#6&2b2c0574&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
12:38:06: chosen type: YUY2, usingFourCC: false, res: 1280x800 - 1280x800, frameIntervals: 1000000-2000000, fourCC: 'YUY2'
12:38:06: audio device: Disable,
12:38:06: audio device id Disabled,
12:38:06:
12:38:08: Using directshow input
12:38:08: Using bitmap image
12:38:09: ------------------------------------------
12:38:09: device: Dazzle DVC100 Video,
12:38:09: device id \\?\usb#vid_2304&pid_021a&mi_00#6&18795a3d&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
12:38:09: chosen type: YUY2, usingFourCC: false, res: 720x480 - 720x480, frameIntervals: 333667-333667, fourCC: 'YUY2'
12:38:09: audio device: Dazzle DVC100 Audio Device,
12:38:09: audio device id \\?\usb#vid_2304&pid_021a&mi_01#6&18795a3d&0&0001#{33d9a762-90c8-11d0-bd43-00a0c911ce86}\wave,
12:38:09:
12:38:10: Using directshow input
12:38:11: ------------------------------------------
12:38:11: Video Encoding: x264
12:38:11: fps: 30
12:38:11: width: 728, height: 456
12:38:11: preset: veryfast
12:38:11: CBR: no
12:38:11: CFR: no
12:38:11: max bitrate: 2400
12:38:11: buffer size: 2400
12:38:11: quality: 7
12:39:11: Total frames rendered: 890, number of frames that lagged: 332 (37.30%) (it's okay for some frames to lag)
12:39:12: =====Stream End: 2013-07-22, 12:39:12=================================================
12:39:13:
12:39:13: Profiler results:
12:39:13:
12:39:13: ==============================================================
12:39:13: frame - [100%] [avg time: 52.159 ms (cpu time: avg 7.852 ms, total 6988.85 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.243%]
12:39:13: | frame preprocessing and rendering - [20.3%] [avg time: 10.607 ms (cpu time: avg 4.066 ms, total 3619.23 ms)] [avg calls per frame: 1] [children: 11.1%] [unaccounted: 9.27%]
12:39:13: | | scene->Preprocess - [11.1%] [avg time: 5.773 ms (cpu time: avg 2.839 ms, total 2527.22 ms)] [avg calls per frame: 1]
12:39:13: | video encoding and uploading - [79.4%] [avg time: 41.425 ms (cpu time: avg 3.768 ms, total 3354.02 ms)] [avg calls per frame: 1] [children: 78.6%] [unaccounted: 0.824%]
12:39:13: | | flush - [6.71%] [avg time: 3.501 ms (cpu time: avg 0.297 ms, total 265.2 ms)] [avg calls per frame: 1]
12:39:13: | | CopyResource - [0.771%] [avg time: 0.402 ms (cpu time: avg 0.07 ms, total 62.4 ms)] [avg calls per frame: 0]
12:39:13: | | conversion to 4:2:0 - [1.74%] [avg time: 0.906 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
12:39:13: | | call to encoder - [69.3%] [avg time: 36.143 ms (cpu time: avg 3.312 ms, total 2948.42 ms)] [avg calls per frame: 0]
12:39:13: | | sending stuff out - [0.0824%] [avg time: 0.043 ms (cpu time: avg 0.017 ms, total 15.6 ms)] [avg calls per frame: 0]
12:39:13: | Convert444Threads - [129%] [avg time: 67.415 ms (cpu time: avg 2.541 ms, total 2262.01 ms)] [avg calls per frame: 0]
12:39:13:
dodgepong
Administrator
Community Helper
What do you mean by "crashing"? You mean just disconnectiong? Or does OBS actually crash?
That is a really bad CPU for streaming, by the way. It is very slow at video encoding. I recommend lowering your preset to ultrafast and your frame rate to 25fps, and maybe downscale some more. That will hopefully stop you from lagging so many frames, but I'm not making any promises.
