I have a problem starting the stream by means of nvenc h.264 Any type of error log?
E Elgato1277 New Member Aug 27, 2018 #1 I have a problem starting the stream by means of nvenc h.264 Any type of error log? Attachments 2018-08-26 18-30-57.txt 16.7 KB · Views: 26
koala Active Member Aug 27, 2018 #2 In the stream settings, set GPU from 8 to 0. You only have 1 GPU, so the only value that will work is 0.
