I've been trying to stream to Twitch.tv for the past few days, but some viewers have said that it is stuttering a lot. The log is as follows:
Speedtest.net results:
I experience no stutter when watching any of the videos, but people say they do. For example this video: http://www.twitch.tv/wolphoenix/b/363785794
Anyone have any hints for me on how to improve the stream and get rid of the stutter? Also, I am using the installer version and for some reason it starts the 32 bit version of OBS most of the time. Could that be related to the stutter?
Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 690
Video Adapter Dedicated Video Memory: 2062221312
Video Adapter Shared System Memory: 2147479552
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (ASUS Xonar Essence STX Audio Device)
Audio Encoding: AAC
bitrate: 320
Using graphics capture
Video Encoding: x264
fps: 60
width: 1920, height: 1080
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 4000
quality: 10
SharedTexCapture hooked
Server selection: rtmp://live-fra.justin.tv/app
bufferTime: 1966, outputRateWindowTime: 1000, dropThreshold: 2466
Total frames rendered: 14113, number of frames that lagged: 286 (2.03%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 7.211 ms] [avg calls per frame: 1] [children: 97.4%] [unaccounted: 2.62%]
| scene->Preprocess - [0.0555%] [avg time: 0.004 ms] [avg calls per frame: 1]
| video encoding and uploading - [97.3%] [avg time: 7.018 ms] [avg calls per frame: 1] [children: 26.6%] [unaccounted: 70.8%]
| | CopyResource - [0.208%] [avg time: 0.015 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.111%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | call to encoder - [26.1%] [avg time: 1.884 ms] [avg calls per frame: 0]
| | sending stuff out - [0.111%] [avg time: 0.008 ms] [avg calls per frame: 0]
