Hi everyone I can't figure out why i lag when streaming in game.
Was hoping to get suggestions on setting or minor/small changes to my pc build.
Its 3 years old and needs alot of upgrades but the stats are
[I have a basic understanding of what im doing through the manual but not sure why]
Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz [CPU]
8GB of DDR3 [RAM]
win7 64bit [OS]
Zotac Geforce GTX 550 Ti [Graphics Card]
ASUS Sabertooth P67 [Motherboard]
Corsair GS600 [Power supply]
I dont know what other info that might help.
8GB of DDR3 [RAM]
win7 64bit [OS]
16:03:11: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
16:03:11: -------------------------------
16:03:11: CPU Name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
16:03:11: CPU Speed: 3193MHz
16:03:11: Physical Memory: 4095MB Total, 3809MB Free
16:03:11: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
16:03:11: monitor 1: pos={0, 0}, size={1600, 900}
16:03:11: Windows Version: 6.1 Build 7600
16:03:11: Aero is Enabled
16:03:11: OBS Modules:
16:03:11: Base Address Module
16:03:11: 00220000 OBS.exe
16:03:11: 69B00000 OBSApi.dll
16:03:11: 6C160000 DShowPlugin.dll
16:03:11: 71170000 GraphicsCapture.dll
16:03:11: 71150000 NoiseGate.dll
16:03:11: ------------------------------------------
16:03:11: Adapter 1
16:03:11: Video Adapter: NVIDIA GeForce GTX 550 Ti
16:03:11: Video Adapter Dedicated Video Memory: 1025179648
16:03:11: Video Adapter Shared System Memory: 3220779008
16:03:11: =====Stream Start: 2013-05-12, 16:03:11===============================================
16:03:11: Multithreaded optimizations: On
16:03:11: Base resolution: 1280x720
16:03:11: Output resolution: 1280x720
16:03:12: Loading up D3D10...
16:03:12: Playback device Default
16:03:12: ------------------------------------------
16:03:12: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:03:12: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:03:12: Audio Encoding: AAC
16:03:12: bitrate: 256
16:03:12: Using bitmap image
16:03:12: Video Encoding: x264
16:03:12: fps: 60
16:03:12: width: 1280, height: 720
16:03:12: preset: veryfast
16:03:12: CBR: no
16:03:12: CFR: no
16:03:12: max bitrate: 1800
16:03:12: buffer size: 2000
16:03:12: quality: 10
16:03:12: Bad timestamp detected, syncing audio to video time
16:03:18: Total frames rendered: 404, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:03:18: =====Stream End: 2013-05-12, 16:03:18=================================================
16:03:19: =====Stream Start: 2013-05-12, 16:03:19===============================================
16:03:19: Multithreaded optimizations: On
16:03:19: Base resolution: 1280x720
16:03:19: Output resolution: 1280x720
16:03:19: ------------------------------------------
16:03:19: Loading up D3D10...
16:03:19: Playback device Default
16:03:19: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:03:19: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:03:19: Audio Encoding: AAC
16:03:19: bitrate: 256
16:03:19: Using bitmap image
16:03:20: ------------------------------------------
16:03:20: Video Encoding: x264
16:03:20: fps: 60
16:03:20: width: 1280, height: 720
16:03:20: preset: veryfast
16:03:20: CBR: no
16:03:20: CFR: no
16:03:20: max bitrate: 1800
16:03:20: buffer size: 2000
16:03:20: quality: 10
16:03:20: Bad timestamp detected, syncing audio to video time
16:03:22: Total frames rendered: 133, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:03:22: =====Stream End: 2013-05-12, 16:03:22=================================================
16:03:36: =====Stream Start: 2013-05-12, 16:03:36===============================================
16:03:36: Multithreaded optimizations: On
16:03:36: Base resolution: 1280x720
16:03:36: Output resolution: 1280x720
16:03:36: ------------------------------------------
16:03:36: Loading up D3D10...
16:03:36: Playback device Default
16:03:36: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:03:36: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:03:36: Audio Encoding: AAC
16:03:36: bitrate: 256
16:03:36: Using bitmap image
16:03:36: Video Encoding: x264
16:03:36: fps: 60
16:03:36: width: 1280, height: 720
16:03:36: preset: veryfast
16:03:36: CBR: no
16:03:36: CFR: no
16:03:36: max bitrate: 1800
16:03:36: buffer size: 2000
16:03:36: quality: 10
16:03:36: Bad timestamp detected, syncing audio to video time
16:03:46: Total frames rendered: 603, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:03:46: =====Stream End: 2013-05-12, 16:03:46=================================================
16:07:01: =====Stream Start: 2013-05-12, 16:07:01===============================================
16:07:01: Multithreaded optimizations: On
16:07:01: Base resolution: 1280x720
16:07:01: Output resolution: 1280x720
16:07:01: ------------------------------------------
16:07:01: Loading up D3D10...
16:07:01: Playback device Default
16:07:01: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:07:01: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:07:01: Audio Encoding: AAC
16:07:01: bitrate: 256
16:07:01: Using bitmap image
16:07:01: Video Encoding: x264
16:07:01: fps: 60
16:07:01: width: 1280, height: 720
16:07:01: preset: veryfast
16:07:01: CBR: no
16:07:01: CFR: no
16:07:01: max bitrate: 1800
16:07:01: buffer size: 2000
16:07:01: quality: 10
16:07:01: Bad timestamp detected, syncing audio to video time
16:07:17: Total frames rendered: 961, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:07:17: =====Stream End: 2013-05-12, 16:07:17=================================================
16:07:17: =====Stream Start: 2013-05-12, 16:07:17===============================================
16:07:17: Multithreaded optimizations: On
16:07:17: Base resolution: 1280x720
16:07:17: Output resolution: 1280x720
16:07:17: ------------------------------------------
16:07:17: Loading up D3D10...
16:07:17: Playback device Default
16:07:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:07:17: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:07:17: Audio Encoding: AAC
16:07:17: bitrate: 256
16:07:17: Using bitmap image
16:07:17: Video Encoding: x264
16:07:17: fps: 60
16:07:17: width: 1280, height: 720
16:07:17: preset: veryfast
16:07:17: CBR: no
16:07:17: CFR: no
16:07:17: max bitrate: 1800
16:07:17: buffer size: 2000
16:07:17: quality: 10
16:07:17: Bad timestamp detected, syncing audio to video time
16:07:36: Total frames rendered: 1116, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:07:36: =====Stream End: 2013-05-12, 16:07:36=================================================
16:07:37: =====Stream Start: 2013-05-12, 16:07:37===============================================
16:07:37: Multithreaded optimizations: On
16:07:37: Base resolution: 1280x720
16:07:37: Output resolution: 1280x720
16:07:37: ------------------------------------------
16:07:37: Loading up D3D10...
16:07:37: Playback device Default
16:07:37: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:07:37: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:07:37: Audio Encoding: AAC
16:07:37: bitrate: 256
16:07:37: Using bitmap image
16:07:37: Video Encoding: x264
16:07:37: fps: 60
16:07:37: width: 1280, height: 720
16:07:37: preset: veryfast
16:07:37: CBR: no
16:07:37: CFR: no
16:07:37: max bitrate: 1800
16:07:37: buffer size: 2000
16:07:37: quality: 10
16:07:37: Total frames rendered: 0, number of frames that lagged: 0 (-1.#J%) (it's okay for some frames to lag)
16:07:37: =====Stream End: 2013-05-12, 16:07:37=================================================
16:07:39: =====Stream Start: 2013-05-12, 16:07:39===============================================
16:07:39: Multithreaded optimizations: On
16:07:39: Base resolution: 1280x720
16:07:39: Output resolution: 1280x720
16:07:39: ------------------------------------------
16:07:39: Loading up D3D10...
16:07:39: Playback device Default
16:07:39: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:07:39: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:07:39: Audio Encoding: AAC
16:07:39: bitrate: 256
16:07:39: Using bitmap image
16:07:39: Video Encoding: x264
16:07:39: fps: 60
16:07:39: width: 1280, height: 720
16:07:39: preset: veryfast
16:07:39: CBR: no
16:07:39: CFR: no
16:07:39: max bitrate: 1800
16:07:39: buffer size: 2000
16:07:39: quality: 10
16:07:39: Bad timestamp detected, syncing audio to video time
16:07:45: Total frames rendered: 407, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:07:46: =====Stream End: 2013-05-12, 16:07:46=================================================
16:07:55: =====Stream Start: 2013-05-12, 16:07:55===============================================
16:07:55: Multithreaded optimizations: On
16:07:55: Base resolution: 1280x720
16:07:55: Output resolution: 1280x720
16:07:55: ------------------------------------------
16:07:55: Loading up D3D10...
16:07:55: Playback device Default
16:07:55: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:07:55: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:07:55: Audio Encoding: AAC
16:07:55: bitrate: 256
16:07:55: Using Window Capture
16:07:55: Video Encoding: x264
16:07:55: fps: 60
16:07:55: width: 1280, height: 720
16:07:55: preset: veryfast
16:07:55: CBR: no
16:07:55: CFR: no
16:07:55: max bitrate: 1800
16:07:55: buffer size: 2000
16:07:55: quality: 10
16:07:55: Bad timestamp detected, syncing audio to video time
16:07:57: Using bitmap image
16:07:59: Using bitmap image
16:08:00: Using Window Capture
16:08:02: Using Window Capture
16:08:03: Using bitmap image
16:08:16: Using bitmap image
16:08:38: Total frames rendered: 2606, number of frames that lagged: 1 (0.04%) (it's okay for some frames to lag)
16:08:38: =====Stream End: 2013-05-12, 16:08:38=================================================
16:08:39: =====Stream Start: 2013-05-12, 16:08:39===============================================
16:08:39: Multithreaded optimizations: On
16:08:39: Base resolution: 1280x720
16:08:39: Output resolution: 1280x720
16:08:39: ------------------------------------------
16:08:39: Loading up D3D10...
16:08:39: Playback device Default
16:08:39: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:08:39: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:08:39: Audio Encoding: AAC
16:08:39: bitrate: 256
16:08:39: Using bitmap image
16:08:39: Using Window Capture
16:08:39: Video Encoding: x264
16:08:39: fps: 60
16:08:39: width: 1280, height: 720
16:08:39: preset: veryfast
16:08:39: CBR: no
16:08:39: CFR: no
16:08:39: max bitrate: 1800
16:08:39: buffer size: 2000
16:08:39: quality: 10
16:08:39: Bad timestamp detected, syncing audio to video time
16:08:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:08:40: New Scene
16:08:40: Using Monitor Capture
16:08:43: Using Monitor Capture
16:08:45: Using Monitor Capture
16:09:04: Total frames rendered: 761, number of frames that lagged: 599 (78.71%) (it's okay for some frames to lag)
16:09:04: =====Stream End: 2013-05-12, 16:09:04=================================================
16:09:06: =====Stream Start: 2013-05-12, 16:09:06===============================================
16:09:06: Multithreaded optimizations: On
16:09:06: Base resolution: 1280x720
16:09:06: Output resolution: 1280x720
16:09:06: ------------------------------------------
16:09:06: Loading up D3D10...
16:09:06: Playback device Default
16:09:06: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:09:06: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:09:06: Audio Encoding: AAC
16:09:06: bitrate: 256
16:09:06: Using bitmap image
16:09:06: Using Window Capture
16:09:06: Video Encoding: x264
16:09:06: fps: 60
16:09:06: width: 1280, height: 720
16:09:06: preset: veryfast
16:09:06: CBR: no
16:09:06: CFR: no
16:09:06: max bitrate: 1800
16:09:06: buffer size: 2000
16:09:06: quality: 10
16:09:06: Bad timestamp detected, syncing audio to video time
16:09:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:09:08: New Scene
16:09:08: Using Monitor Capture
16:09:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:09:17: New Scene
16:09:17: Using bitmap image
16:09:17: Using Window Capture
16:09:36: Total frames rendered: 1524, number of frames that lagged: 304 (19.95%) (it's okay for some frames to lag)
16:09:36: =====Stream End: 2013-05-12, 16:09:36=================================================
16:09:38: =====Stream Start: 2013-05-12, 16:09:38===============================================
16:09:38: Multithreaded optimizations: On
16:09:38: Base resolution: 1280x720
16:09:38: Output resolution: 1280x720
16:09:38: ------------------------------------------
16:09:38: Loading up D3D10...
16:09:38: Playback device Default
16:09:38: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:09:38: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:09:38: Audio Encoding: AAC
16:09:38: bitrate: 256
16:09:38: Using bitmap image
16:09:38: Using Window Capture
16:09:38: Video Encoding: x264
16:09:38: fps: 60
16:09:38: width: 1280, height: 720
16:09:38: preset: veryfast
16:09:38: CBR: no
16:09:38: CFR: no
16:09:38: max bitrate: 1800
16:09:38: buffer size: 2000
16:09:38: quality: 10
16:09:38: Bad timestamp detected, syncing audio to video time
16:10:35: Total frames rendered: 3400, number of frames that lagged: 1 (0.03%) (it's okay for some frames to lag)
16:10:35: =====Stream End: 2013-05-12, 16:10:35=================================================
16:10:36: =====Stream Start: 2013-05-12, 16:10:36===============================================
16:10:36: Multithreaded optimizations: On
16:10:36: Base resolution: 1280x720
16:10:36: Output resolution: 1280x720
16:10:36: ------------------------------------------
16:10:36: Loading up D3D10...
16:10:36: Playback device Default
16:10:36: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:10:36: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:10:36: Audio Encoding: AAC
16:10:36: bitrate: 256
16:10:36: Using bitmap image
16:10:36: Using Window Capture
16:10:36: Video Encoding: x264
16:10:36: fps: 60
16:10:36: width: 1280, height: 720
16:10:36: preset: veryfast
16:10:36: CBR: no
16:10:36: CFR: no
16:10:36: max bitrate: 1800
16:10:36: buffer size: 2000
16:10:36: quality: 10
16:10:36: Bad timestamp detected, syncing audio to video time
16:10:37: Total frames rendered: 65, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:10:38: =====Stream End: 2013-05-12, 16:10:38=================================================
16:10:39: =====Stream Start: 2013-05-12, 16:10:39===============================================
16:10:39: Multithreaded optimizations: On
16:10:39: Base resolution: 1280x720
16:10:39: Output resolution: 1280x720
16:10:39: ------------------------------------------
16:10:39: Loading up D3D10...
16:10:39: Playback device Default
16:10:39: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:10:39: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:10:39: Audio Encoding: AAC
16:10:39: bitrate: 256
16:10:39: Using bitmap image
16:10:39: Using Window Capture
16:10:39: Video Encoding: x264
16:10:39: fps: 60
16:10:39: width: 1280, height: 720
16:10:39: preset: veryfast
16:10:39: CBR: no
16:10:39: CFR: no
16:10:39: max bitrate: 1800
16:10:39: buffer size: 2000
16:10:39: quality: 10
16:10:39: Bad timestamp detected, syncing audio to video time
16:10:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:41: New Scene
16:10:41: Using Monitor Capture
16:10:43: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:10:43: New Scene
16:10:43: Using bitmap image
16:10:43: Using Window Capture
16:11:10: Total frames rendered: 1822, number of frames that lagged: 62 (3.40%) (it's okay for some frames to lag)
16:11:10: =====Stream End: 2013-05-12, 16:11:10=================================================
16:11:10: =====Stream Start: 2013-05-12, 16:11:10===============================================
16:11:10: Multithreaded optimizations: On
16:11:10: Base resolution: 1280x720
16:11:10: Output resolution: 1280x720
16:11:10: ------------------------------------------
16:11:10: Loading up D3D10...
16:11:10: Playback device Default
16:11:10: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:11:10: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:11:10: Audio Encoding: AAC
16:11:10: bitrate: 256
16:11:10: Using bitmap image
16:11:10: Using Window Capture
16:11:10: Video Encoding: x264
16:11:10: fps: 60
16:11:10: width: 1280, height: 720
16:11:10: preset: veryfast
16:11:10: CBR: no
16:11:10: CFR: no
16:11:10: max bitrate: 1800
16:11:10: buffer size: 2000
16:11:10: quality: 10
16:11:10: Bad timestamp detected, syncing audio to video time
16:11:13: Total frames rendered: 162, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
16:11:13: =====Stream End: 2013-05-12, 16:11:13=================================================
16:11:16: =====Stream Start: 2013-05-12, 16:11:16===============================================
16:11:16: Multithreaded optimizations: On
16:11:16: Base resolution: 1280x720
16:11:16: Output resolution: 1280x720
16:11:16: ------------------------------------------
16:11:16: Loading up D3D10...
16:11:16: Playback device Default
16:11:16: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:11:16: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:11:16: Audio Encoding: AAC
16:11:16: bitrate: 256
16:11:16: Using Monitor Capture
16:11:16: Video Encoding: x264
16:11:16: fps: 60
16:11:16: width: 1280, height: 720
16:11:16: preset: veryfast
16:11:16: CBR: no
16:11:16: CFR: no
16:11:16: max bitrate: 1800
16:11:16: buffer size: 2000
16:11:16: quality: 10
16:11:16: Bad timestamp detected, syncing audio to video time
16:11:17: Total frames rendered: 32, number of frames that lagged: 31 (96.88%) (it's okay for some frames to lag)
16:11:17: =====Stream End: 2013-05-12, 16:11:17=================================================
16:13:13: =====Stream Start: 2013-05-12, 16:13:13===============================================
16:13:13: Multithreaded optimizations: On
16:13:13: Base resolution: 1280x720
16:13:13: Output resolution: 1280x720
16:13:13: ------------------------------------------
16:13:13: Loading up D3D10...
16:13:13: Playback device Default
16:13:13: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:13:13: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:13:13: Audio Encoding: AAC
16:13:13: bitrate: 256
16:13:13: Using bitmap image
16:13:13: Using Window Capture
16:13:13: Video Encoding: x264
16:13:13: fps: 60
16:13:13: width: 1280, height: 720
16:13:13: preset: veryfast
16:13:13: CBR: no
16:13:13: CFR: no
16:13:13: max bitrate: 1800
16:13:13: buffer size: 2000
16:13:13: quality: 10
16:13:13: Bad timestamp detected, syncing audio to video time
16:13:17: Using Window Capture
16:13:18: Using Window Capture
16:13:19: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:13:19: New Scene
16:13:19: Using Monitor Capture
16:13:20: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:13:20: New Scene
16:13:20: Using bitmap image
16:13:20: Using Window Capture
16:13:49: Using Monitor Capture
16:14:22: Total frames rendered: 3009, number of frames that lagged: 902 (29.98%) (it's okay for some frames to lag)
16:14:22: =====Stream End: 2013-05-12, 16:14:22=================================================
16:14:22: =====Stream Start: 2013-05-12, 16:14:22===============================================
16:14:22: Multithreaded optimizations: On
16:14:22: Base resolution: 1280x720
16:14:22: Output resolution: 1280x720
16:14:22: ------------------------------------------
16:14:22: Loading up D3D10...
16:14:22: Playback device Default
16:14:22: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:14:22: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:14:22: Audio Encoding: AAC
16:14:22: bitrate: 256
16:14:22: Using Monitor Capture
16:14:22: Using bitmap image
16:14:22: Using Window Capture
16:14:23: ------------------------------------------
16:14:23: Video Encoding: x264
16:14:23: fps: 60
16:14:23: width: 1280, height: 720
16:14:23: preset: veryfast
16:14:23: CBR: no
16:14:23: CFR: no
16:14:23: max bitrate: 1800
16:14:23: buffer size: 2000
16:14:23: quality: 10
16:14:23: Bad timestamp detected, syncing audio to video time
16:14:26: Total frames rendered: 121, number of frames that lagged: 121 (100.00%) (it's okay for some frames to lag)
16:14:26: =====Stream End: 2013-05-12, 16:14:26=================================================
16:14:26: =====Stream Start: 2013-05-12, 16:14:26===============================================
16:14:26: Multithreaded optimizations: On
16:14:26: Base resolution: 1280x720
16:14:26: Output resolution: 1280x720
16:14:26: ------------------------------------------
16:14:26: Loading up D3D10...
16:14:26: Playback device Default
16:14:26: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:14:26: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:14:26: Audio Encoding: AAC
16:14:26: bitrate: 256
16:14:26: Using Monitor Capture
16:14:27: Using bitmap image
16:14:27: Using Window Capture
16:14:27: ------------------------------------------
16:14:27: Video Encoding: x264
16:14:27: fps: 60
16:14:27: width: 1280, height: 720
16:14:27: preset: veryfast
16:14:27: CBR: no
16:14:27: CFR: no
16:14:27: max bitrate: 1800
16:14:27: buffer size: 2000
16:14:27: quality: 10
16:14:27: Bad timestamp detected, syncing audio to video time
16:14:28: Using RTMP service: Twitch / Justin.tv
16:14:28: Server selection: rtmp://live.justin.tv/app
16:14:29: SO_SNDBUF was at 8192
16:14:29: SO_SNDBUF is now 65536
16:15:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:36: New Scene
16:15:36: Using Monitor Capture
16:15:52: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:15:52: New Scene
16:15:52: Using Monitor Capture
16:15:52: Using bitmap image
16:15:52: Using Window Capture
16:17:13: Total frames rendered: 6115, number of frames that lagged: 6082 (99.46%) (it's okay for some frames to lag)
16:17:13: RTMPPublisher::SocketLoop: Aborting due to bStopping
16:17:13: Number of times waited to send: 0, Waited for a total of 0 bytes
16:17:13: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:17:13: =====Stream End: 2013-05-12, 16:17:13=================================================
16:18:03: =====Stream Start: 2013-05-12, 16:18:03===============================================
16:18:03: Multithreaded optimizations: On
16:18:03: Base resolution: 1280x720
16:18:03: Output resolution: 1280x720
16:18:03: ------------------------------------------
16:18:03: Loading up D3D10...
16:18:03: Playback device Default
16:18:03: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:18:03: Using auxilary audio input: Microphone (Logitech Mic (Communicate STX))
16:18:03: Audio Encoding: AAC
16:18:03: bitrate: 256
16:18:03: Using Window Capture
16:18:03: Using bitmap image
16:18:03: Using Monitor Capture
16:18:03: Video Encoding: x264
16:18:03: fps: 60
16:18:03: width: 1280, height: 720
16:18:03: preset: veryfast
16:18:03: CBR: no
16:18:03: CFR: no
16:18:03: max bitrate: 1800
16:18:03: buffer size: 2000
16:18:03: quality: 10
16:18:03: Bad timestamp detected, syncing audio to video time
16:20:44: Using Window Capture
16:21:19: Total frames rendered: 6304, number of frames that lagged: 4354 (69.07%) (it's okay for some frames to lag)
16:21:19: =====Stream End: 2013-05-12, 16:21:19=================================================
16:21:20:
16:21:20: Profiler results:
16:21:20:
16:21:20: ==============================================================
16:21:20: frame - [100%] [avg time: 15.019 ms] [avg calls per frame: 1] [children: 96.9%] [unaccounted: 3.12%]
16:21:20: | scene->Preprocess - [88.1%] [avg time: 13.233 ms] [avg calls per frame: 1]
16:21:20: | video encoding and uploading - [8.77%] [avg time: 1.317 ms] [avg calls per frame: 1] [children: 8.64%] [unaccounted: 0.127%]
16:21:20: | | CopyResource - [0.133%] [avg time: 0.02 ms] [avg calls per frame: 0]
16:21:20: | | conversion to 4:2:0 - [0.0666%] [avg time: 0.01 ms] [avg calls per frame: 0]
16:21:20: | | call to encoder - [8.41%] [avg time: 1.263 ms] [avg calls per frame: 0]
16:21:20: | | sending stuff out - [0.0333%] [avg time: 0.005 ms] [avg calls per frame: 0]
16:21:20:
16:21:20: Memory Leaks Were Detected.
16:21:20:
