Question / Help How to fix obs fps drop?
visanimusic
Hello guys!
I try to issue solo but after 1 billion time to trying without success i deside to post question here.
Now lets move forward to the question:
How to fix problem with streaming Far Cry Primal - fps in obs studio (720p) 17-24 , fps in game 50-67.
PC Configuration:
AMD FX-8350
ASrock 970 Extreme3 r2.0
GTX 1050 TI WindForce 4GB
RAM: A-Data 1600 16GB 4x4GB DDR3
2x22" monitors 1680x1050
Internet: Upload ~32mbps Download ~81mbps
I Streaming with this settings:
Stream:
Service: Twitch
Server: EU: Prague,CZ - best for my internet
Output:
Output Mode: Advanced
Encoder: x264
Enforce streaming service encoder settings - checked
Rescale Output: checkd and set to 1280x720
Rate Control: CBR
Bitrate: 2500-2800 (i try it to change and both and didn't have difference)
Use custom buffer size: uncheck
Keyframe Interval: 2
CPU Preset: veryfast (i try and on Slow and dont have any problems to stream)
Profile: Main
Video:
Base Resolution: 1680x1050
Output (scaled) Resolution: 1280x720
Downscale filter: Lanczos
FPS: 30
The problem is that : When i play INgame everything is good but in OBS fps is 17-24 can't get stable 30fps.
Ingame settings everything is on low as possible to prevent problems but still have same fps in OBS.
I try to stream on bordeless , windowed and fullscreen and still have the problem.
How to fix it? I will so greathfull if someone can help me. This happening only in Far Cry Primal and Hard Truck Simulator 2 but in HTS fps si variable and get 30fps only Far Cry Primal can't. Thank to everyone who try to help me !
There is and Log from OBS Studio:
http://pastebin.com/Jgxjc9Qc
  • 2017-02-09 16-30-40.txt
