How to add audio from osmo pocket 3 to obs
agassijoel
Hi, I have successfully added Osmo Pocket 3 as a webcam but am not getting the audio.
can someone suggest to me how to do it? please see the attached screenshot.
It's possible that the camera identifies itself as two separate devices - silent picture and blind sound - instead of a single device that does both. if that's the case, then the video capture will always be silent, but you'll have an additional sound card that you can capture the audio from separately.
