Hotkeys with Lua script
FakiR
Hello!
I want to write a script that will write an increasing value to a file. The script code is in the attachments.
It works, but the hotkey works twice. When a hot key is pressed once, the value 2 will be written to the file, not 1.
Where did I make a mistake?
  • testhk.txt
Mango
I have the same problem. The function appears to fire both on key down and key up. Any suggestions would be appreciated.
Using 26.1.1 on Windows. Nothing appears in the log.
Mango
I figured out how to fix it:
Lua:
function instant_replay(pressed)
 if not pressed then
  return
 end
 team1_score = team1_score + 1
 write_to_file("team1", team1_score)
end
