Bug Report Hotkeys Captured By OBS Even If Not An Active Application
chitetskoy
This is a minor but yet annoying bug in the OBS Studio (0.13.4).
Hotkeys gets captured by the OBS Studio application even when it is not an active (or current) application.
How to reproduce the bug:
1. Open OBS Studio
2. Assign hotkeys if none assigned yet.
3. Go to another application, for example, Notepad and press some keys that is the same as one of the assigned hotkeys in OBS Studio.
Expected behavior:
1. Keys will be read only by the active application (in this case, Notepad)
Actual behavior:
1. Notepad captures the shortcut key and OBS Studio in the background also captures the hotkey.
Machine Specs:
HP Laptop, I3 4th Gen Processor, 4gb RAM, Windows 8.1
R1CH
This is the intended use of hotkeys, so you can switch scenes etc without having to go into OBS.
chitetskoy
Ah thanks. So far I am doing the workaround by assigning rarely-used three-key combo (such as Ctrl+Alt+1) in the hotkeys and is doing fine. I am wondering if it is possible to enable option to "capture hotkeys when app is active", unless if it cause significant performance degradation on the OBS.
